MIT problem set problem, I have problems with the solutions
  • Thread starter Thread starter flyingpig
    Mit Set
7 replies · 3K views
flyingpig
Wow that was three problems in my title. Anyways please go to this link
http://stuff.mit.edu/afs/athena/course/8/8.02-esg/Spring03/www/8.02pset2sol3.pdf
and go to problem 4: 24.28
I have a question to the solutions
a) They constructed a bigger cylinder for their Gaussian surface. Now my question is, is the thin cylindrical shell itself a charge and that is why we must construct our own surface?
What happens if the [tex]\vec{E}[/tex] field is 36kN/C at 7.00cm?
b) Why is it 0? Why can't you just replace 19cm with 4.00cm?
I can't understand what are you asking
It depends on the side of surface. Inside the material its 0, just outside ... follow formula used in (a), inside its 0 again
Because according to gauss law, flux or even E is directly disproportional to charge in-closed by the surface.
Does it matter if it is even a thin cylindrical shell? Can it be a solid?
Yes, I plug in 4, I get a number
But it doesn't mean it can't right?
No, even if its solid, you need to use a Gaussian surface ... Gaussian surface i just a hypothetical surface ... it may even coincide with your cylinder's outer surface!
You can use a formula made for 1 thing for something else but it will give a wrong result. same is happening with you!
No there can't be any field ... you know that charges on conductor resides on surfaces ...most probably on outer to reduce its potential energy
so draw the figure of cylindrical shell we're talking about ... draw charge on outer surface ... and you see there is no charge inside to provide electric field! the outer charge provides field to outer area. This concept in electrostatic shielding
[tex](3.60x10^4) = \frac{2(8.99x10^9)\frac{Q}{2.4}}{4.00cm}[/tex]
I don't understand
Can someone please help me!
Wait, is it because the radial E-field outside the surface of the shell?
Look at the pic
If charge is + or -, E will be outside the area,
you think there will be field inside too. can you tell me why?
