Can Mixed Units in Ratios Be Converted and Used Accurately in Calculations?
  • Thread starter Thread starter photon184739
    Mixed Ratio Units
The discussion centers on the accurate conversion and calculation of mixed units in ratios, specifically involving centripetal acceleration (a_c) in kilometers per hour squared and tangential acceleration (a_t) in kilometers per hour per second. Participants emphasize the necessity of converting all units to the International System of Units (SI) before performing calculations to avoid inaccuracies. The correct approach involves converting kilometers to meters and hours to seconds, ensuring that both components of acceleration are expressed in compatible units for accurate vector addition.
  • Understanding of centripetal acceleration and tangential acceleration
  • Knowledge of unit conversion between kilometers, meters, hours, and seconds
  • Familiarity with vector addition of orthogonal components
  • Proficiency in dimensional analysis and unit consistency
  • Learn about SI unit conversions for speed and acceleration
  • Study vector addition and the Pythagorean theorem in physics
  • Explore dimensional analysis techniques for verifying calculations
  • Investigate common pitfalls in mixed unit calculations and how to avoid them
Students and professionals in physics, engineering, and mathematics who require a solid understanding of unit conversions and vector addition in calculations involving mixed units.
photon184739
The driver of a car moving at 90.0 km/h presses down on the brake as the car enters a circular curve of radius 150.0 m. If the speed of the car is decreasing at a rate of 9.0 km/h each second, what is the magnitude of the acceleration of the car at the instant its speed is 60.0 km/h?
(Openstax Physics 1 Chapter 4 q. 81)
a_c = v^2/r (centripetal acceleration)
a = a_c + a_t (centripetal and tangential acceleration)
I have the solution, but my question is that in my first attempt, I simply calculated a_c = 60^2/150 ignoring the fact that the units for 60 are km/hr and the units for 150 are meters. Is this ever salvageable? Is there any way to retain the 'mixed' units of km with meters in the ratio and apply a conversion factor, or is information lost and the approach should be 'scrapped'?
Why don't you write the first part out in long form, including all units. See where that takes you. Then work on combining the two accelerations.
Also, this equation is incorrect. Quantities ac and at are orthogonal components of the acceleration vector. Simply adding them is incorrect if your goal is to find the magnitude.
You need to do something about the hour also, unless you want your acceleration to be ##m/h^2##.
The best way is to convert kilometers to meters and hours to seconds before entering values into the equation.
As has been mentioned, if in doubt, carry the units through your calculation. $$\frac{(60 \text{km}\text{h}^{-1})^2}{150\text{m}} = \frac{3600 \times (10^3 \text{m})^2 \times (3600s)^{-2}}{150 \text{m}} = \text{etc.}$$ @Lnewqban's method has the benefit that if you always use SI units, the units will simplify into the standard SI unit for the new calculated quantity, which can save lot of work!
etotheipi said:
As has been mentioned, if in doubt, carry the units through your calculation. $$\frac{(60 \text{km}\text{h}^{-1})^2}{150\text{m}} = \frac{3600 \times (10^3 \text{m})^2 \times (3600s)^{-2}}{150 \text{m}} = \text{etc.}$$ @Lnewqban's method has the benefit that if you always use SI units, the units will simplify into the standard SI unit for the new calculated quantity and that means we don't need to worry much about the units except for giving the final answer.
Perhaps. Since the question has already chosen the units by giving the tangential acceleration not in SI but as ##a_t=9.0~\mathrm{\dfrac{km/hr}{s}}##, I would say that the magnitude of the acceleration should be given in the same units. All one has to do is convert the centripetal acceleration as calculated by OP, ##a_c=\dfrac{(60~\mathrm{km/hr)^2}}{150~\mathrm m}## into these same units.
Whoops, I didn't even see that part of the question. When we do the addition in ##a = \sqrt{a_t^2 + a_n^2}## the two evidently have to have the same units in order to 'factorise the units out' in the addition.
  • · Replies 19 ·
