Mobile Comms: Number of Cells in Hexagonal Pattern
  • Topic: Engineering
  • Thread starter Master1022
    Cells Mobile
5 replies · 2K views · last reply
Master1022
Why is the number of cells in the radius ## D ## determined by ## N_c = D_R^2 ## where ## D_R = \sqrt{i^2 + j^2 + ij} ##
area
Hi,
I was looking at some notes and trying to understand the following statement which refers to the diagram below.
"The number of cells in the radius ## D ## determined by ## N_c = D_R^2 ## where ## D_R = \sqrt{i^2 + j^2 + ij} ##
where ## i## and ##j## are the number of cells along the ## u ## and ## v ## axes respectively.
Hexagonal cell grid with v axis vertical and u axis at pi/6 to the horizontal; cells labelled A at u1,v1 and B at u2,v2, with ticks 1 to 3 along the u and v axes.
From what I understand, B is at (2, 2) in (u, v) coordinates and radius ##D## is ## = \sqrt{2^2 + 2^2 + (2)(2)} \cdot R \sqrt{3} ##. Therefore, the number of cells within the radius ## D ## should be ## 12 ##. I cannot see how this is the case, no matter how I try to encircle cells...
I think I am missing something quite simple. Any help would be greatly appreciated.
I think that the formula Nc = i2 +j2 +ij refers to the number of hexagonal cells in a "cluster", where clusters are distanced by i and j.
[edited for additional clarity]
For i=2, j=2, this results in clusters that share cells, fractionally. Add the fractional cells to the non-shared cells and you will get 12.
Thank you very much for your reply @lewando !
I am struggling to picture this on the image... Is there any chance you could edit/add something to the image posted to show what you are saying? I will keep trying to think about it in the meantime.
Perhaps if you study this image you will see what I mean by fractional cells. The black dots are distanced by i=2, j=2. [edited to match your original orientation]
Hand-drawn hexagonal cell grid on paper with three coloured clusters (green, red, yellow) of seven hexagons each, meeting at a shared corner, with black dots marking cell centres.
FWIW, with a change of grid origin, you can get a different cluster pattern that eliminates the fractional cells:
Hexagonal cell grid with three clusters of highlighted cells in green, pink and yellow, each joined to black dots at cluster centres and at outer corners by thin lines.
Thank you very much @lewando for taking the time to produce those pictures! They are extremely helpful!
