Modeling an earthing switch for a High Voltage Impulse Generator
This discussion focuses on modeling an earthing switch mechanism for a High Voltage Impulse Generator using a solenoid to lift an aluminum arm. The user has derived the force on the armature from electromagnetic modeling software and is attempting to create equations of motion for the armature. They have expressed challenges in formulating the dynamic equations and have considered static force analysis instead. The conversation highlights the complexities of dynamic modeling and the potential for state-space approaches, although the user ultimately found a static analysis more manageable.
  • Understanding of solenoid mechanics and operation
  • Familiarity with kinematics and dynamics of linkages
  • Knowledge of static and dynamic force analysis
  • Experience with electromagnetic modeling software
  • Research dynamic modeling techniques for mechanical systems
  • Learn about state-space modeling in control systems
  • Explore advanced friction modeling in mechanical systems
  • Investigate software tools for simulating mechanical linkages
Engineers, mechanical designers, and researchers involved in modeling electromechanical systems, particularly those working with solenoids and linkage mechanisms.
Angus Fergusson
TL;DR
Modelling a seemingly simple mechanism that is proving to be quite challenging
Hi All,
I am trying to model this mechanism for a project. It is a switch that uses a solenoid to break the contact by lifting the aluminium arm. I understand that there is most likely software out there that can do this but i would like to understand how to model this from first principals.
I have got a function for the force on the armature of the solenoid from an electromagnetic modeling software. The force on the armature is the input to the system. I want the motion of the armature, Y, as the output of the model.
So far I have found Y and its derivatives in terms of theta and beta which are the angle of the link 2 (crank) and the angle of link 3 (con rod), respectively. I have also found beta and its derivatives in terms of theta (meaning that i effectively have Y in terms of theta). After that there is the force balance on each link. I have left friction on the armature out for now, F_mu.
At the moment I am struggling with creating the equations of motion of the armature (Ydotdot = TotalForceOnArmature/MassOfArmature). Any help would be greatly appreciated
Thanks in advance!
Welcome to PF.
I assume the white arm is the earthed contact arm, and it is attached to the elbow link.
All points in the linkage appear to travel in circular arcs, except the solenoid, which moves in a straight line.
The arc through which the white arm travels, restricts the range that must be modelled.
Are you modelling the dynamic flight of the arm as a result of the predicted solenoid force, or the static force required to move the arm through, or to hold the arm in a particular position?
Originally tried to do the dynamic flight but found the algebra for that to be far too complicated. I considered a state-space approach but do not have enough knowledge to pull that off. Ended up just doing a static force analysis to find the friction between the solenoid armature and the housing, which was then iterated to get the friction as a function of the position of the armature in the solenoid housing.
And yes you are correct with the mechanics of the linkage.
The model is no longer needed but I would love to hear if there is a better approach to the problem.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 27 ·
11K
