Modeling the Earth-Sun system in Quantum Mechanics
The forum discussion focuses on modeling the Earth-Sun system using quantum mechanics by replacing the Coulomb potential with a gravitational potential, represented as V(r) = -GMm/r. The participant calculated the Bohr radius for this system as a_g = ħ²/(GMm²) and derived the energy expression E_n = -G²M²m³/(2n²ħ²). They encountered difficulties with large numerical values and approximations, particularly in calculating the quantum number for Earth, n_e = √(r/a_g), which resulted in an extraordinarily large value (~2.5 * 10^71). The discussion emphasizes the impracticality of applying quantum mechanics at planetary scales and suggests using Taylor expansion for energy difference calculations.
  • Understanding of gravitational potential energy in classical mechanics
  • Familiarity with quantum mechanics concepts, particularly the Bohr model
  • Proficiency in mathematical techniques such as Taylor expansion
  • Experience with numerical calculations involving large and small values
  • Explore the implications of gravitational potential in quantum mechanics
  • Learn about Taylor series and their applications in physics
  • Investigate the limitations of quantum mechanics at macroscopic scales
  • Study the relationship between quantum numbers and energy levels in various systems
Students and researchers in physics, particularly those interested in quantum mechanics and gravitational systems, as well as educators looking to illustrate the limitations of quantum mechanics in large-scale applications.
eep
Hi,
We recently solved the hydrogen atom and one of our homework problems asks us to replace the coloumb potential with a gravitational potential. I have the potential as being
<br /> V(r) = -\frac{GMm}{r}<br />
Where M is the mass of the sun, m the mass of the earth. I have calculated the Bohr radius to be:
<br /> a_g = \frac{\hbar^2}{GMm^2}<br />
However my calculator chokes on this value. I managed to get an approximation for it by first multiplying and dividing all decimal values, then doing the needed multiplication, addition and subtraction for the powers of 10. Needless to say I get something ridiculously small.
I have an expression for the energy of state n as
<br /> E_n = \frac{-G^2M^2m^3}{2n^2\hbar^2}<br />
I am then supposed to find out what Earth's quantum number is by assuming a classical, circular orbit, so I do:
<br /> E_n = \frac{-GMm}{2r}<br />
where r is the distance from the Earth to the sun. Substitute in the above expression and calculate n. This gives me that
<br /> n_e = \sqrt{\frac{r}{a_g}}<br />
Which is some insanely large number (~2.5 * 10^{71}). I'm then supposed to calculate how much energy would be released if the Earth were to jump down to the next quantum number, and what the wavelength of the photon (or graviton, as the book suggests) would be in light years. I'm having some serious problems computing this quality as my TI-83 chokes, and when I make some approximations I get something like \deltaE = 7.68 * 10^-6 which seems much much too small.
First, are my calculations correct? Second, how can I compute these numbers?
Err, do you know at what distance scale QM becomes relevant ?
What's the criterium we use to decide at what distance scale quantummechanical effects will arise ?
Think about that for a while, please, it'll save you a lot of trouble.
marlon
eep said:
my TI-83 chokes
Try the Microsoft calculator on your computer. It can handle very large numbers.
Something tells me that this exercise is supposed to give him an idea of the answer to that question.
eep said:
Hi,
I agree with all your expressions.
And the fact that you get "ridiculously" large numbers is to be expected, it is part of the goal of the exercise, to make you realize that it would be ridiculous to use quantum mechanics on the scale of planets or even moons, space shuttles, etc.
For the problem with the choking part, I haev a suggestion. You iwl have to calculate -{C \over n^2} + {C \over (n-1)^2 } where C is the bunch of constants appearing in the energy equation. The problem is due to the n being so large. So what you should do is to use a Taylor expansion.
Write
{1 \over n^2-2n+1} \approx {1 \over n^2 -2n} = {1 \over n^2(1-2/n)} = {1\over n^2} {1 \over (1-2/n)} \approx {1\over n^2} (1+ {2 \over n}) = {1\over n^2} + {2 \over n^3}
Now, when you take a difference of energy, the 1/n^2 pieces will cancel out leaving only 2C/n^3 and that's your difference of energy.
Hope this helps
Patrick
  • · Replies 18 ·
