Molarity of a solution of silver perchlorate
  • Thread starter Thread starter n108
    Molarity Silver
The discussion revolves around calculating the molarity of various solutions, specifically focusing on silver perchlorate and other compounds. Participants also explore related concepts such as balancing chemical equations and understanding molar ratios in reactions.
  • Homework-related
  • One participant asks for the molarity of a silver perchlorate solution and provides multiple choice answers, expressing uncertainty about their own guess.
  • Another participant questions the understanding of the original poster, suggesting that they clarify their approach to the problems presented.
  • A participant suggests using an online resource to find the molarity equation, indicating a reliance on external references for clarification.
  • In a separate discussion, a participant describes the formation of aluminum oxide and expresses confusion about balancing the chemical equation and determining the moles needed for a reaction.
  • Another participant provides the correct formula for aluminum oxide and discusses the stoichiometry involved in the reaction.
  • Further clarification is offered regarding the conservation of atoms in reactions and the importance of valence electrons in forming compounds.
  • A participant expresses gratitude for the information received and seeks further clarification on how to determine the molar ratio for aluminum oxide.
Participants do not reach a consensus on the molarity calculations, and there is ongoing confusion regarding the balancing of chemical equations and the application of molar ratios. Multiple viewpoints and uncertainties are present throughout the discussion.
Some participants express uncertainty about their calculations and understanding of chemical concepts, indicating a need for further exploration of the topics discussed. The discussion includes various assumptions about chemical bonding and stoichiometry that remain unresolved.
Students and individuals seeking assistance with chemistry homework, particularly in understanding molarity, chemical equations, and stoichiometry.
n108
What is the molarity of a solution of silver perchlorate, AgClO4, if 3.2 moles of silver perchlorate is dissolved in 1.5 liters of water? Is it 2.133 M, 4.756 M, 4.8 M, or 4.810 M ?
i guessed 2.133 M
2. How many moles of potassium iodide, KI, must be used to make 1.500 L of a 0.2 M solution?
.3 m
.2 M
.2 m I know its not this one...
.2 g
3. What is the molarity of the solution produced when 151 g of sodium chloride, NaCl is dissolved in enough water to prepare .375 L of solution?
.469 M this one is wrong
9.456 M
3.57 M
6.89 M
4. How many grams of potassium chloride, KCl, are needed to prepare 0.630 L of a 2.50 M solution of potassium chloride?
1.575 M
117 g
2.54 m
23.19 g this one is wrong
Can you explain what it is about these questions that gives you trouble? We can't really help if we don't know how you're approaching the problem.
You must have some ideas, how else can you say those answers are the wrong ones?
n108;
Google "molarity", go to the first reference, and look at the equation on the top of the site. Good luck.
Steve
ok, I think my mind is clearing up a little bit...better.
thanks
balancing equations
Problem #1:
Aluminum oxide is formed from the reaction of metallic aluminum with oxygen gas. How many moles of Aluminum are needed to form 3.4 moles of Aluminum oxide?
Hint: This is a simple ratio problem. Just use the molar ratio from the balanced equation. Mass is not involved.
Ok, so I know that aluminum has 3 valence electrons and oxygen, which is diatomic, has 6 valence electrons. And I know that there needs to be 8 electrons to make a compound. but 3 + 6 is 9, not 8. I also learned about the different types of bonds, ionic bonds, covalent bonds, metallic bonds. So I can guess that this is a covalent bond where I electron is shared by both.
But I still don't understand how to write the chemical compound equation, and how to balance it, for Aluminum oxide.
Help!
Aluminum Oxide:
Al2O3
That shows for 1 formula unit, two of Aluminum and three of Oxygen.
(Is there a way to form subscripts in this forum?)
You don't even need to balance the equations, simply use principle of conservation of (particluar) atom species, for eg in the above reaction, its Al.
Also, when you form compounds, care about the valence electrons of individual atoms, eg. you said Oxygen atom has 6 electrons. So its short of two, while Aluminium has 3 extra.
In simplest form the balanced eqn looks like this (this is not needed but still )
2Al \ + \ \frac{3}{2}O_2 \longrightarrow \ Al_2 O_3
Thank you!
So now I know the formula for aluminum oxide: Al2O3. How do I find out how many moles are needed to form 3.4 moles of aluminum oxide?
The hint says: "This is a simple ratio problem. Just use the molar ratio from the balanced equation. Mass is not involved."
How do I the molar ratio of aluminum oxide?
Al2 to O3 = 2/3?
That doesn't seem right...
9K
17K
17K
