Molarity of Unknown and sodium hydroxide.
The discussion centers on determining the identity of an unknown acid (hydrochloric, sulfuric, or phosphoric) with a concentration of 0.2128 M, using a titration method with 0.2723 M sodium hydroxide. A total of 32.83 mL of sodium hydroxide was required to titrate 21.00 mL of the unknown acid. The key to solving the problem lies in calculating the moles of H+ ions present, which must be an integer multiple of the acid's concentration. This approach allows for the identification of the acid based on the stoichiometry of the reaction.
  • Understanding of titration techniques
  • Knowledge of molarity calculations
  • Familiarity with acid-base reactions
  • Ability to calculate moles from volume and concentration
  • Calculate the moles of H+ ions from the titration data
  • Research the stoichiometry of sulfuric, hydrochloric, and phosphoric acids
  • Learn about molar mass calculations in titration contexts
  • Explore the concept of equivalence points in acid-base titrations
Chemistry students, laboratory technicians, and educators involved in acid-base titration experiments and those seeking to enhance their understanding of molarity and stoichiometry in chemical reactions.
imaciel
This is the question:
Your friend gives you an unlabeled bottle that contains either hydrochloric, sulfuric or phosphoric acid. The concentration of the unknown acid is 0.2128 M. A titration of 21.00 mL of the acid with a 0.2723 M sodium hydroxide solution required 32.83 mL of sodium hydroxide. Which of the three acids is in the bottle?
A. sulfuric acid
B. hydrochloric acid
C. phosphoric acid
Steps:
I solved for the molar mass of 3 choices, but I don't know how to get the molar mass from the problem. I can get # of moles in the solution but what about gram?
molar mass= gram/moles...
tnx
Your titration will tell you how many moles of H+ are present. The result should be an integer multiple of 0.2128.
Enough of a hint?
12K
