Calculating Mole Fraction from Molality: Sodium Nitrate Solution Example
The mole fraction of sodium nitrate (NaNO3) in a 2.14 m molal aqueous solution is calculated to be 0.0370. This calculation assumes 1 kg of solvent, resulting in 2.14 moles of NaNO3. The total number of moles includes the moles of water, calculated as 1000 grams divided by the molar mass of water (18 g/mol). For improved accuracy, using a more precise molar mass of water is recommended.
  • Understanding of molality and its calculation
  • Knowledge of mole fraction and its formula
  • Basic chemistry concepts, including moles and molar mass
  • Familiarity with unit conversions (grams to kilograms)
  • Study the calculation of mole fractions in different solute-solvent systems
  • Learn about the impact of temperature on molar mass and its implications for calculations
  • Explore advanced topics in solution chemistry, such as colligative properties
  • Review the use of accurate molar masses in chemical calculations
Chemistry students, educators, and professionals involved in solution chemistry and calculations related to molality and mole fractions.
Qube
The molality of an aqueous sodium nitrate solution is 2.14 m. What is the mole fraction of sodium nitrate?
Molality = moles of solute / kg of solvent.
Mole fraction of A = moles of A / total number of moles (in this case, moles of solute + moles of solution).
Assuming we have 1 kg of solvent, we can assume we have 2.14 moles of NaNO3.
Mole fraction of NaNO3 is therefore 2.14 / [(1000/18) + 2.14] = 0.0370.
1000/18 because 1000 grams of water is present and there are 18 grams per mole of water. The grams cancel out and yield moles of water.
Looks OK. You will get slightly better result by using more accurate molar mass of water.
I appreciate your consideration and helpfulness!
