Molecular Vibrations: Rotational and Translational Movement
  • Context: Undergrad
  • Thread starter Thread starter Iceking20
The discussion centers around the movement of solid particles, specifically whether they exhibit rotational, translational, or vibrational motion. Participants explore these concepts in the context of solids, liquids, and gases, touching on theoretical and conceptual aspects of molecular behavior.
  • Some participants propose that atoms in a solid form a lattice structure that restricts them to vibrational motion without translational or rotational movement.
  • Others argue that while a macroscopic solid has many internal vibrational degrees of freedom, it can still exhibit some translational and rotational motion, though these motions may not significantly affect the quantum description of the solid.
  • A participant mentions that in an idealized infinite crystal, atomic motions can be decomposed into normal modes, including translational and optical phonons, which are relevant to the discussion of solid particle movement.
  • Another contribution highlights that phonons in solids primarily consist of acoustic and optical vibrations, which involve small linear translations of atoms rather than rotation.
  • Some participants note the existence of rattling modes in certain crystal structures, where atoms can move within cages, leading to different vibrational behaviors.
  • A later reply introduces the concept of chiral phonons, which involve rotational motion within certain materials, suggesting that there are exceptions to the general behavior of solid particles.
  • Additionally, it is mentioned that some spherical-shaped molecules can form plastic crystals, allowing for rotation while being fixed in their crystal positions, contrasting with typical liquid crystal behavior.
Participants express a range of views regarding the movement of solid particles, with no consensus reached on whether solid particles can rotate or translate. The discussion remains unresolved, with multiple competing perspectives presented.
Limitations include the dependence on specific definitions of motion and the complexity of molecular interactions in different states of matter, which are not fully resolved in the discussion.
Iceking20
TL;DR
Do solid particles rotate or transit or they just vibrate?
Summary: Do solid particles rotate or transit or they just vibrate?
Do solid particles move rotationaly and transitionally or all of these for liquid and gas?
Are you asking about molecules that form solids?
Yes
To the best of my knowledge (this is not my field), the atoms in a solid form some sort of a lattice structure which holds them in place - no transit or rotation. I don't believe molecules exist independently.
Any N-particle system in 3 dimensions has 3N degrees of freedom. 3 are pure translations and 3 are pure rotations; hence the typical formula for molecules as having 3N-6 internal (vibrational) degrees of freedom.
For a macroscopic solid, N is huge (a solid weighing a few grams will have nearly Avogadro’s number of atoms), so the internal degrees of freedom dwarf the translations and rotations. But of course a finite object can still rotate and translate—it’s just that those motions don’t contribute significantly to the quantum description of the solid.
In the idealized case of an infinite crystal (like you might encounter in a class on solid state physics), nuclear motions are generally only considered over a single unit cell. In this case, if the unit cell contains N atoms, it still has 3N degrees of freedom (assuming the cell is 3-dimensional). But now the atomic motions of a unit cell are going to affect the motions of the neighboring cells. 3 of the modes will look like translational modes—these correspond to acoustic phonons and have zero energy at zero crystal momentum. The other 3N-3 modes correspond to optical phonons, which have a nonzero energy at zero crystal momentum.
Edit for clarity: in general, any atom in a crystal can move in any direction. However, these motions can be decomposed into a set of 3N normal modes—eigenstates of the vibrational Hamiltonian that are orthogonal to one another (that is, their ##L^2## inner product is zero).
When atoms condense into a solid, then, as TeethWhitener pointed out, the primary modes are acoustic and optical phonons. These are vibrations that move as a wave through the material, ie: they are collective modes due to long range coordination of the atoms. In fact, they are guaranteed to exist since they are the Goldstone mode associated with long range ordering of the crystalline lattice. So back to your question:
When these phonons vibrate, this typically consists of small linear translations of the individual atoms. I am not sure if this is what you are asking when you use the word transit, but they definitely do not rotate.
However, it should be stressed that you can still sometimes find other modes in materials. For instance, there exist rattling modes where the crystal structure includes cages with atoms confined inside. These atoms can then rattle about which often leads to a glassiness or lifetime decay of the more traditional acoustic and optical phonons. Cages themselves can have a flexing or breathing like mode. These are effectively local modes with collective behavior confined to individual cages. This is in stark contrast to standard phonons that recruit atoms across many many unit cells. However, recently a material has been discovered where the collective phonon propagation across the material does actually consist of rotations referred to as chiral phonons. See this link for a gif of the material in action.
https://newscenter.lbl.gov/2018/02/...mic-rotations-in-a-2-d-semiconductor-crystal/ As a final example, you can also have single molecules that are embedded in a material that can rotate quasi-independent of the lattice. As an example, look at Fig 1 a,b of this paper:
https://arxiv.org/ftp/arxiv/papers/1612/1612.01631.pdf
Some compounds whose molecules are roughly spherical in shape can form a plastic crystal, in which the molecules are fixed in their crystal positions (can't translate), but can freely rotate - kind of the opposite of a liquid crystal. E.g. sulfolane between 16 and 28°C.
  • · Replies 0 ·
  • · Replies 83 ·
  • · Replies 156 ·
12K
