Molecule collisions in an Ideal Gas
The discussion focuses on the analysis of molecule collisions in an ideal gas, specifically addressing the probability distribution function P(t) = Ae^(-bt) governing the time between collisions. The normalization constant A is determined to be A = b, ensuring that the integral of P(t) from 0 to infinity equals 1. The average time between collisions, denoted as tau, is derived using the expected value E(t) = ∫tP(t)dt from 0 to infinity. Additionally, the standard deviation of the collision times, σ_t, is to be calculated based on the established probability distribution.
  • Understanding of probability density functions
  • Familiarity with integration techniques in calculus
  • Knowledge of expected value calculations for continuous distributions
  • Basic concepts of ideal gas behavior
  • Study the derivation of the normalization constant in probability distributions
  • Learn about calculating expected values for continuous random variables
  • Explore the concept of standard deviation in the context of probability distributions
  • Investigate the implications of the ideal gas law on molecular behavior
Students studying thermodynamics, physicists interested in statistical mechanics, and anyone seeking to understand the behavior of gases at the molecular level.
derravaragh
Molecules in an ideal gas collide with each other at random times. The probability distribution governing the time between collisions is P(t) = Ae^(-bt).
(a) Find the value of A so that P(t) is correctly normalized.
(b) Find the average time between collisions, t. This time is traditionally called tau. Now re-write P(t) in terms of tau, without the original parameters A and b.
(c) Find the standard deviation of the collision times, σ_t.
∫(x^n)e^(-x/a)dx = n!a^(n+1) from 0 to ∞
I believe I have the right answer to (a), I normalized it to obtain P(t) = -be^(-bt), but I can't figure out what to do for part (b) on.
My attempt was to take the average time t to equal (ƩP(t))/n where n is the number of collisions and the sum goes from 0 to ∞, but that thought process got me no where. Any help would be appreciated.
I don't think the first part is right. The integral of P(t) from t=0 to t=infinity should be +1.
If you have the probability density function p(x) for some continuous variable X, what expression gives the average value of X?
For the first response, I rechecked my work on part (a) and realized my signs were off, using A = b the ∫Ae^(-bt) from 0 to ∞ gives me a value of +1.
For the second response, the only solution I can think of would be the Expected value E(x) which would give E(t) = ƩtP(t) = Ʃt(Ae^(-bt)) from t = 0 to ∞ which gives 0 + be^(-b) + 2be^(-2b) +...+ 0 which I don't know how to generalize or even how to apply to the next part. Quite frankly, I am lost on this problem after part (a).
The mean time is an expectation value. It's going to be the integral of t*P(t) from 0 to infinity.
That's for a discrete distribution. As Dick says, the equivalent for a continuous distribution is integration.
  • · Replies 32 ·
