How to Calculate Moment of a Couple Using Cross Products?
The discussion focuses on calculating the moment of a couple using cross products in physics. The user initially calculated the moment about an axis defined by a unit vector of (-0.6i -0.8j) and found a magnitude of 3663. However, confusion arose regarding the correct answer choices, leading to a clarification that the moment is determined by the cross product of position vectors (r) and forces (F) for each point of application. The correct approach involves finding the components of r and F for both points A and B, calculating their cross products, and summing them to obtain the total moment.
  • Understanding of vector operations, specifically cross products
  • Familiarity with the concepts of torque and moment in physics
  • Knowledge of unit vectors and their application in force analysis
  • Ability to decompose vectors into their x and y components
  • Study the calculation of moments using cross products in physics
  • Learn how to decompose vectors into components for force analysis
  • Explore examples of torque calculations in two-dimensional systems
  • Practice problems involving multiple forces and their resultant moments
Students studying physics, particularly those focusing on mechanics, engineers dealing with force analysis, and anyone interested in understanding the application of cross products in calculating moments.
lc99
I am confused. It looks like the couple forces are at a angle pointing to the x axis.
So i did moment about a axis of that angle.
I found this angle/axis unit vector to be (-0.6i -0.8j)
Then i found the moment couple about the x and y-axis and the magnitude is 3663.
Multiplied it by the unit vector and found its magnitude as 3663. However the answer is not in the choice!
We know the couple/moment/torque is r x F and the direction is ccw from the sketch thus you can eliminate e) and f). So you just need to find the x and y components of each r and F, take the cross products and sum them.
Quick question. I am working on another problem and it is killing me...
I keep getting 5/2 and the answer should be e. 5/4m/
I found that Fr = -4F1
and Moment about the left point is -10F1
so M = F*d --> d = 5/2 or x=5/2
but it is not right??
I do not know what that means. Please explain.
Can't tell where you went wrong without seeing the details.
Further Dr Dr news' post, you can choose what point you take along the line of action of each force as the point of application. You can do this in such a way that only one of the two components has a moment about the axis.
lc99 said:
Im working on another problem and it is killing me...
Please post a new thread - as per forum style.
Back to the original problem. Find r(A) = - 8 i + 8 j and F(A) = - 72 i + 96 j. Then do the same for r(B) and F(B). Take the cross products r x F for each of A and B and sum them.
  • · Replies 40 ·
  • · Replies 21 ·
26K
