Moment of inertia (formula problem)
The discussion revolves around the concept of moment of inertia, specifically regarding the different formulas used for a slender rod when calculating rotational inertia about different axes. Participants explore the implications of using different values of inertia and the context in which each formula applies.
  • Participants attempt to understand why two different values of inertia are used for the same slender rod, questioning the interchangeability of these values in calculations. They discuss the context of using the formulas for different points of rotation and express confusion regarding specific examples from the material.
Some participants express a growing understanding of the topic, noting the importance of the point about which the moment of inertia is calculated. There is acknowledgment of the need to clarify the application of the formulas, and while some questions remain, productive dialogue is occurring regarding the concepts involved.
Participants mention specific examples from the material, indicating that the discussion is framed within the constraints of a textbook or instructional context. There is a recognition of potential gaps in foundational understanding that may affect the interpretation of the formulas.
sseebbeekkk
1. Material
2. Questions:
a) (pink) Why does the author use two different values of inertia for the same slender rod ?
[/B]
a) I could assume that 1/3 is holding it at the end and 1/12 is holding it in the center.
But it's not interchangeable because if I chose 1/3 instead of 1/12 in the example (17.10) I would get totally different final result.
They are the rotational inertias about the end and about the center, respectively. It is up to you to figure out which is the most useful point for calculating moments in any particular problem. (Sometimes it doesn't matter.)
Realize that 17.10 uses both values of rotational inertia. :)
Ok, thank you :)
Ok I have realized that I don't understand it fully (I miss something basic probably)
According to this example we should calculate the moment of inertia using formula I=1/12ml2+md2
So why did the author in 17.10 use simply [1/12ml2]*α
Instead of [1/12ml2+md2]*α
Only because you want the moment of inertia about point O.
Because the author was calculating the moment of inertia about the center of mass, not the end of the rod.
Ok, finally I understand it (hope so)
I can choose I=1/12ml2 = in that case (17.10) 1/12*20*32=15
or I=1/3ml2 = (center at 1.5) 1/3*20*1,52=15
It works :biggrin:EDIT: but if that what I have just written is true, I have got the following question:
Why did the author write in 17.12 (1/3ml2) instead of 1/3m * (l/2)2 ?
Don't do that!
In both formulas, the "l" stands for the length of the rod. It's the same value in both formulas. The moment of inertia about one end (the 1/3 formula) is different from the moment of inertia about the center (the 1/12 formula).
That was very concise and clear.
Thank you :-)
