Moment of inertia of a half disk about an axis
The discussion revolves around calculating the moments of inertia of a half disk with uniform density, specifically focusing on the setup of the problem and the interpretation of the equations involved.
  • Participants explore the setup of the moment of inertia calculation, questioning the definitions of angles and the resulting expressions for the integrals involved. There is a focus on whether the definitions of angle φ align between the original poster and the instructor.
Participants are actively questioning the validity of the expressions for the moment of inertia and whether the differences in the integrals (using sin²(φ) versus cos²(φ)) affect the outcome. Some suggest that the integral evaluates to the same result, while others recommend confirming definitions with the instructor.
There is an emphasis on ensuring consistent definitions of the angle φ, which may impact the interpretation of the problem setup. The original poster expresses uncertainty regarding the instructor's notes, indicating potential discrepancies in understanding.
vbrasic
Consider a half disk (of uniform density) with the flat end lying on the x-axis, symmetric about the y-axis (i.e. being cut into two quarters by the y-axis). Calculate the moments of inertia about each of the axes.
$$I_{rr}=\sum_{i}m_ir_i^2$$
I just need some making sure that I'm setting up the problem correctly.
The distance to the x-axis from any point on the disk is ##y##. Or, alternatively, ##r\sin{\phi}.## So we find that, $$I_{xx}=\int_{0}^{R}\int_{0}^{\pi}(r^2\sin^2{\phi})\rho\,rdrd\phi,$$ where ##\rho## is the mass density per unit area. However, my instructor has in his notes that, $$I_{xx}=\int_{0}^{R}\int_{0}^{\pi}(r^2\cos^2{\phi})\rho\,rdrd\phi.$$ I'm not sure why that would be, as the distance from any point to the axis of rotation (x in the case of ##I_{xx}## is ##y=r\sin{\rho}.##
I think you have it right. Maybe the instructor wrote it down wrong.
Have you and your instructor defined angle ##\phi## the same way or is one ##90^o - \phi## of the other?
vbrasic said:
... in the case of ##I_{xx}## is ##y=r \sin \rho##.
You mean ##y=r \sin \phi##.
Yes -- and not that I know of.
OK, then you need to ask yourself, "does it make any difference?" Is the area under the ##\cos^2(\phi)## curve from ##0## to ##\pi## different from the area under the ##\sin^2(\phi)## curve? Draw the curves and see for yourself.
Yeah, it wouldn't make a difference. The integral evaluates to the same result either way.
Yes, and if you want to satisfy your curiosity, you may have to ask your instructor about the definition of ##\phi##, otherwise leave it alone.
  • · Replies 28 ·
  • · Replies 45 ·
