Moment of inertia of a hoop about a point
The moment of inertia of a circular wire hoop about a point on the hoop is calculated using the equation Izz = Izz(cm) + M(x^2 + y^2). For a hoop with mass m and radius r, the moment of inertia about any point on the hoop is determined to be 2mr^2. The discussion highlights the challenges faced in deriving Ixx and Iyy using parametric equations and integrals, ultimately leading to the conclusion that the inertia tensor components can be derived from the center of mass values.
  • Understanding of moment of inertia concepts
  • Familiarity with polar and parametric equations
  • Knowledge of integral calculus
  • Basic mechanics principles related to inertia tensors
  • Study the derivation of moment of inertia for different shapes
  • Learn about inertia tensor calculations in three dimensions
  • Explore applications of parametric equations in physics
  • Review integral calculus techniques, particularly u-substitution
Students studying physics, particularly those focusing on mechanics, as well as educators and professionals involved in engineering and physical sciences who require a deeper understanding of moment of inertia calculations.
MasterNewbie
Find the moment of inertia of a circular wire hoop about a point on the hoop.
mass = m
radius = r
Izz = Iyy + Ixx
Well, using the above equation I first tried to solve for Ixx. Since we are looking for the moment of inertia about a point on the hoop I picked an arbitrary point on the hoop to be the origin for the calculation. With my chosen system the hoop would appear suspended from the origin, x-axis running from left to right, y-axis bottom to top and z-axis behind to front.
Ixx = m\int\int(y2+z2)dydx
z is 0 so it drops from the equation, leaving m\int\int(y2)dydx
My issue is trying to find some function to model the curve. At first I attempted to use polar coordinates but I couldn't find an equation that would give the shape of the hoop in my coordinate system. Then I used parametric equations for each x and y. x = cos(t) and y = 1 - sin(t), 0<t<2\pi for my limits. dy = -cos(t) and dx = -sin(t). Making those substitutions in the integral and evaluating it I found that one of the integral steps requires a u-substitution, and changing the limits of integration to reflect the substitution would make both limits the same (integral = 0) which doesn't make much sense to me. After that I stopped trying to get Ixx
Trying to find Iyy For this, because shifting the hoop vertically won't affect the distance each point is away from the y-axis, I made the center of the hoop the origin in this calculation. This let me write x = \sqrt{r^2 - y^2}. Setting up the integral, m\int\intx2dxdy, with the inner limit between 0 and the above equation for x, and for the y limits, -r/2 and r/2. This would give one side of the loop so I multiplied by 2 to include both sides. Evaluating the inner integral, I get 2m\int\sqrt{R^2-y^2}3dy which is evaluated with a trig-sub. However when I make the substitution, because the root is being cubed and an extra r arising from the dy=rcos\varthetad\vartheta, r4 can be pulled out, making it dimensionally inconsistent with the moment of inertia. I spotted a mistake I made while writing this so I will continue again, but I don't think it will work out with an extra r2 outside.
I want to apologize for my obvious terribleness with the equation writing feature here on these forums.
I dug through my mechanics book, and there is an equation you can use to calculate the components of the inertia tensor about any point, if you know the components of the tensor about the center or mass. Keeping in mind the point is displaced from the cm by (x,y,z) (so for mine x=z=0, y=-r)
Izz = Izz(cm) + M(x^2+y^2), since x^2+y^2=r^2 regardless of any point on the hoop, and the moment of inertia of a thin hoop is mr^2, Izz about any point on the hoop is 2mr^2.
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 28 ·
