Moment of inertia of a hoop on an arm
The moment of inertia of a hoop at the end of an arm is calculated using the formula Ihoop = Mr2 + Md2 when applying the parallel axis theorem. The total moment of inertia for the system is Itotal = Ihoop + Iarm, where Iarm is defined as Iarm = (md2) / 3. If the axis of rotation is at the opposite end of the arm, the calculation must account for the radius of the hoop and the distance from the pivot point, resulting in Ihoop = Mr2 + M(r + d)2. Neglecting the thickness of the hoop increases the moment of inertia, complicating the model's predictions.
  • Understanding of moment of inertia concepts
  • Familiarity with the parallel axis theorem
  • Basic knowledge of rotational dynamics
  • Ability to apply mathematical equations related to physics
  • Study the parallel axis theorem in detail
  • Learn about the moment of inertia for composite bodies
  • Explore the effects of thickness on moment of inertia calculations
  • Investigate torque and angular velocity relationships in rotational systems
Physics students, mechanical engineers, and anyone involved in modeling rotational dynamics in mechanical systems will benefit from this discussion.
Integral
Staff Emeritus
Find the moment of Inertial of a hoop at the end of a arm. The axis is at the end of the arm and normal to the plane of the hoop.
Let:
M= mass of the hoop
r= radius of the hoop
m=mass of the arm
d=lengh of the arm
I_{hoop} = Mr^2
I_{arm} = \frac {md^2} 3
I_{total} = I_{hoop} + I_{arm}
Using the parallel axis theorem the hoop:
I_{hoop} = Mr^2 +Md^2
so for the system:
Question, is this correct?
Here's the deal, I have created a model of this system, but it is not responding as I think it should, the moment of Inertia is something I need to verify.
No this is not homework for a class, but it is typical of a homework problem so this is where is belongs.
Does the axis of rotation pass through the centre of the hoop or is it at the opposite end of the arm?
If the axis of rotation passes through the centre of the hoop, then your calculation is correct. One possibility for the misbehavior of the model is that both your momenta of inertia (rod and hoop) assume that their thickness is negligible. If the thicknesses of your hoop/rod is not negligible then you should use the following momenta of inertia;
I_{hoop} = \frac{1}{2}M(r_0^2+r_1^2)
Where r0 and r1 are the inner and outer radii respectively. And,
I_{cylinder} = \frac{1}{4}MR^2 + \frac{1}{3}Md^2
But I'm sure that you have considered this already.
Thanks Hoot,
Actually the axis of rotation is through the opposite end. Imagine a flyswatter, edge on. (Won't get many flys this way)
I have neglected the thickness, unfortunately that serves to increase the moment of inertia, which makes my problem worse.
There is a torque applied near the pivot point, the model predicts angular velocity well below what my gut says.
I think for the final Ih I missed the radius of the hoop in the application of the parallel axis theorem. It should read:
Mr^2 + M ( r+d)^2
The physical system has a pair of these paddels rotating on the same axis, I am assuming that I just double I.
Thanks for any input.
Integral said:
Thanks Hoot,
Ahh, I have a picture now :smile:
Mr^2 + M ( r+d)^2
Yes that looks correct to me. unfortunately, it looks as if this new addition will only serve to further compound your 'problem'.
Again, yes, this is totally valid. I'm just sorry that I can't help you further, is this something that your building or is it purely a thought experiement?
this is an attempt to model a real system. I'll keep you up with what I learn.
Thanks Integral, if I think of anything I'll let you know.
  • · Replies 19 ·
16K
  • · Replies 16 ·
