Momentum Conservation of Turntable and Beetle System
The discussion centers on the momentum conservation of a beetle and a turntable system. The beetle, with a mass of 30.0 g, walks on a frictionless turntable with a mass of 80.0 g, initially at rest. The beetle's angular velocity is given as 0.0600 rad/s clockwise relative to the turntable. To determine the angular velocity of the turntable and the beetle's angular velocity with respect to an observer, the conservation of angular momentum must be applied, utilizing the equations L = Iθ and L = mvrsin.
  • Understanding of angular momentum and its conservation
  • Familiarity with the moment of inertia for a uniform disk
  • Knowledge of angular velocity and its directional conventions
  • Ability to apply physical equations in rotational dynamics
  • Study the conservation of angular momentum in isolated systems
  • Learn about moment of inertia calculations for different shapes
  • Explore the relationship between linear and angular velocity
  • Investigate the effects of friction on rotational motion
Students in physics, particularly those studying rotational dynamics, as well as educators and anyone interested in the principles of momentum conservation in mechanical systems.
amb202
A beetle with a mass of 30.0 g is initially at rest on the outer edge of a horizontal turntable that is also initially at rest. The turntable, which is free to rotate with no friction about an axis through its center, has a mass of 80.0 g and can be treated as a uniform disk. The beetle then starts to walk around the edge of the turntable, traveling at an angular velocity of 0.0600 rad/s clockwise with respect to the turntable.
a. With respect to you, motionless as you watch the beetle and turntable, what is the angular velocity of the beetle? Use a positive sign if the answer is clockwise, and a negative sign if the answer is counter-clockwise.
b. What is the angular velocity of the turntable (with respect to you)? Use a positive sign if the answer is clockwise, and a negative sign if the answer is counter-clockwise.
c. If a mark is placed on the turntable at the beetle’s starting point, how long does it take the beetle to reach the mark again?
L= I theta L= mvrsin
I know in order to find the angular velocity of the beetle with respect to me, i need to know the angular velocity of the turntable, but without the radius, i cannot figure out how to find this.
Welcome to PF!
Hi amb202! Welcome to PF! :smile:
Just call the radius r … you'll find it drops out in the end. :wink:
But wouldn't I need the angular velocity of the turntable to figure out the velocity of the beetle with respect to me?
Yes, and you can find that from the information given.
This is physics, not geometry …
you can't solve this just with geometry, you need a physical equation also …
which one do you think it is? :smile:
  • · Replies 17 ·
10K
