Momentum, Impulse, and Collision #2
18 replies · 3K views · last reply
Tastosis
A horizontal force of 0.80 N is required to move a mass M2 = 5kg across the surface with a constant acceleration. With the block initially at rest, a 0.02kg bullet M1 fired horizontally into the block causes the block (with bullet inside) to slide 1.5m before coming to rest again. Find the speed Vo of the bullet.
M1Vo + M2Vo = (M1 + M2) Vf
Should I cancel out M2Vo? Since the block is initially at rest. How do I get Vf? Is it 1.5 m/s?
Hi Tastosis! :smile:
(try using the X2 icon just above the Reply box :wink:)
With question like this, you need to divide the problem into two parts, the collision and after.
During the collision, use conservation of momentum; after the collision use conservation of energy and the work energy theorem; use vf from the first part as vi for the second part. :wink:
Thanks for the tips!
So I use conservation of momentum to solve for Vf which I will use as Vi for the final answer?
I'm stuck. How do I get the velocity initial of the bullet? Do I use the 0.80 N to solve for the time?
No, you use the 0.80 N to find the force of friction (to use in the work energy equation) :wink:
Oh yeah.
From where it stands, here is my equation (I'm still in conservation of momentum):
M1V1 + 0 (since the block is initially at rest) = (M1 + M2) V2
How do I get V1 of bullet?
Yup! :smile:
Now do the work energy equation, using V2 as your initial V. :wink:
Conservation of momentum:
V2 = (M1 * V1) / M1 + M2
V2 = (0.02kg * 1 m/s) / 0.02kg + 50kg
V2 = 0.0004 m/s
Work-energy theorem:
K1 + Wothers = K2
1/2 MV12 + Wothers = 1/2 MV22
V22 = [(0.02kg * (0.0004 m/s)2) + 2 * 0.80 N] / 0.02kg
V22 = 80 m/s
V2 = 8.9 m/s
V2 = 0.0004 m/s
Where did the 1 m/s come from? :confused:
K1 + Wothers = K2
V22 = 80 m/s
V2 = 8.9 m/s
Where is your Wothers ? :confused:
That's my problem, I don't know how to get the V1 of the bullet :confused:
EDIT: My Wothers is the 0.80 N
Your V1 will come from solving both equations simultaneously.
0.80N is a force, isn't it?
W is work.​
Oh, my bad. So W = Fd
But back to the first equation, I have 2 unknowns, V2 and V1?
Get V2 from the second equation, plug it back into the first equation to get V1
I finally get it..I think:
From Conservation of momentum:
V2 = (M1V1) / M1 + M2
Work-energy:
MV12 + 2Wother = MV22
Substitute:
MV12 + 2Wother = M [(M1V1) / M1 + M2]2
Tastosis said:
Work-energy:
You're using the same letters to mean different things.
If they mean the same as in the first equation, then this second equation is wrong.
I don't get it. I thought I can substitute V2 from the first equation to the second equation..since it has the same V2 because the collision was inelastic.
Now I'm confused again :confused: lol
Yes …
your V2 from the first equation becomes your V1 in the second equation.
Your V2 in the second equation is … ? :smile:
I've no idea what this means. :redface:
My V2 from the first equation is...
V2 = (M1V1) / M1 + M2, where
M1 = 0.02kg
M2 = 50kg
V1 = :confused:
