What is the momentum of an object on an incline?
  • Thread starter Thread starter stargirl17
    Incline Momentum
The momentum of an object on an incline can be calculated using the formula p=mv, where p represents momentum, m is mass, and v is velocity. In this discussion, a 5 kg box moving at a constant rate of 2 m/s results in a momentum of 10 kg-m/s. The question regarding the rate of change in momentum requires a different approach, emphasizing the distinction between magnitude and rate of change. The correct answer for the magnitude of the momentum is 10 kg-m/s.
  • Understanding of basic physics concepts, particularly momentum.
  • Familiarity with the formula p=mv for calculating momentum.
  • Knowledge of units of measurement in physics (kg, m/s).
  • Basic understanding of forces acting on objects on an incline.
  • Study the principles of momentum conservation in physics.
  • Learn about the effects of forces on objects on inclines.
  • Explore the concept of rate of change in momentum and its applications.
  • Investigate real-world examples of momentum in sports or vehicle dynamics.
Students studying physics, educators teaching momentum concepts, and anyone interested in understanding the dynamics of objects on inclines.
stargirl17
A 20-Newton force pulling an object up a hill at a constant rate of 2 m/s. The diagram shows a box that is 5 kg on an incline that is 30 m long and 10 m high.
the answers are
1) 0 kg-m/s
2) 10 kg-m/s
3) 100 kg-m/s
4) 600 kg-m/s
The equation for momentum is p=mv
so wouldn't i just do
(5 Kg)(2 m/s)= 10 kg-m/s
yes, if the question is "what is the magnitude of the momentum"
... but for "what is the rate of change in momentum", the answer is different .
yes it was what is the magnitude of the momentum?
thank you :)
