The momentum operator flips the parity of a function, meaning that if a state has parity P = ±1, applying the momentum operator results in a new state with parity P = ∓1. When discussing the del operator, its effect on a function is defined by its action, particularly during a parity transformation where differentiation changes sign for odd and even functions. Differentiating an even function yields an odd function, while a function without well-defined parity remains unchanged. The flipping of parity by the momentum operator is attributed to its differential component, while the constant factor in the operator does not influence parity. Understanding these principles is crucial for grasping the implications of the momentum operator in quantum mechanics.
#1
dyn
774
63
What does it mean when it is said that the momentum operator flips the parity of the function on which it operates ?
It means the following. Suppose you have a state, ##|\psi\rangle## with parity ##P=\pm1##. Then you apply the momentum operator to it, i.e. ##\hat p|\psi\rangle##. Then the parity of the new state is going to be, ##\hat P\left(\hat p|\psi\rangle\right)=\mp\hat p|\psi\rangle##.
#3
dyn
774
63
Thanks for that. In terms of parity what does the del operator do acting on its own ?
#4
Einj
464
59
What do you mean by 'on its own'? An operator is always defined through its action. However (I don't know if this is what you were looking for) when you perform a parity transformation, ##x\to-x## (let's stay in 1 dimension for simplicity) you have that ##\frac{d}{dx}\to-\frac{d}{dx}##. Is this what you want to know?
#5
dyn
774
63
Does this mean if I diiferentiate an even function I get an odd function and vice versa ? If the function is neither odd or even it remains that way after differentiation ?
#6
Einj
464
59
Yes for the first question. If the function doesn't have a well defined parity then you can't really say anything about its derivative.
#7
dyn
774
63
Thanks. My original question was about the momentum operator flipping the parity of functions. It seems as though this is solely due to the differential part of the momentum operator ? The -ih(bar) part of the operator doesn't affect the parity ?
#8
Einj
464
59
Well, that's a constant, which by definition is an even function under parity.
