Most effective of 1000 groups given mean median mode and N
The discussion revolves around identifying the most critical bus stop based on delay contributions, utilizing statistical measures such as mean, median, mode, and frequency of occurrences. Participants seek to clarify the definitions and implications of these terms in the context of a project related to bus delays across multiple stops.
  • One participant seeks to determine the most critical bus stop based on delay contributions, using statistical measures from a dataset.
  • Another participant questions the definition of "most critical" and the meaning of "1000 times" in relation to the provided frequency values.
  • A participant asks for clarification on what is meant by "compared to the total delay" and whether the delay values are in absolute time or a comparative unit.
  • The original poster clarifies that "most critical" refers to the stop contributing the most to total delay, with frequency indicating how often each stop appears in the data.
  • There is a question about how "total delay in general" is defined, specifically whether it is calculated as mean multiplied by frequency.
  • Another participant notes that the answer may depend on the frequency of buses taking each path and questions the real-life applicability of the scenario.
Participants express uncertainty and seek clarification on key terms and definitions, indicating that there is no consensus on how to define the most critical bus stop or the metrics involved in the analysis.
Participants highlight missing assumptions regarding the definitions of delay contributions and the nature of the data, as well as the implications of using percentages instead of absolute numbers.
reddvoid
Hi,
For a SoC project I am working on I need to select one cell which is most critical.
example, If a bus is going through 1000 stops 1000 times I have mean median mode of delay contribution of that stop compared to the total delay to reach from start to stop point and N (number of times bus has gone through that stop).
How do I get the most critical bus stop of all the stops ?
Thanks&Regards.
Part of data I have -
cell Mean Median Mode Freq
L09LP040L_USBUFX20 1.8 1.9 1.8 19736
L09LP040L_USBUFX08 0.9 0.8 0.7 9461
L09LP040L_USBUFAX16 1.6 1.6 1.6 9439
L09LP040L_USAN2X16 2.0 2.1 2.1 6987
L09LP040L_USAN2X04 2.8 2.8 2.7 5993
L09LP040L_USBUFX14 1.4 1.3 1.3 5406
L09LP030L_USBUFX20 1.5 1.5 1.3 5388
L09LP040L_USND2YX16 1.2 1.2 1.2 4931
L09LP040L_USND2X12 0.8 0.8 0.8 4553
L09LP040L_USIVX18 0.9 1.0 1.0 3908
L09LP040L_USIVX20 1.2 1.3 1.4 3783
L09LP040L_USBUFX16 1.3 1.3 1.3 3594
L09LP040L_USAN2FX12 1.5 1.5 1.1 3489
L09LP030L_USIVX20 0.8 0.8 0.6 3320
L09LP040L_USOR2IX16 1.8 1.8 1.5 3006
What do you mean by "the most critical bus stop"?
What does the "1000 times" mean if your frequency values are all above 1000?
And what do you mean by:
Is a datum like 1.8 in units of time (e.g. 1.8 minutes) or is it in some "comparative" unit like "1.8 times the average time per stop" ?
In the example I gave, by most critical I meant the one which is contributing most to the total delay in general, Frequency is number of times each cell(or stop) is appearing and I gave 1000 times just for example , In the data I have, as you can see the frequencies are different for different cells...
and 1.8 is the percent of total delay contributed by that particular cell (or stop)..
Its like there are some x paths and in x paths there are different cells contributing to the delay of the path
so In all the paths the percent of delay contributed by each cell is calculated. since each cell is occurring multiple times in multiple paths and contributing different delay at different instances, I have taken mean of all the percentage delay contributions for each cell and that is in second column , same way I 've taken median and mode
How is "total delay in general" defined? Just the mean multiplied by the frequency?
Why do you have percentages instead of absolute numbers?
@mfb
Hi,
Like this there are thousands of paths with different cells .
The answer is going to depend on how often buses take each path, isn't it?
Are you dealing with a problem that actually involves buses in real life? They have scheduled routes don't they? There are lots of possible routes in a city that no bus is ever scheduled to take.
  • · Replies 41 ·
