Motion Problem Constant Acceleration from 10 to 50 m/s in 2 secs
  • Thread starter Thread starter Shahab Mirza
    Motion
The problem involves a car accelerating from 10 m/s to 50 m/s over a distance of 60 m, with participants discussing the time taken for this acceleration. The subject area is kinematics, specifically focusing on constant acceleration and motion equations.
  • Participants explore the use of average velocity to determine time, questioning the validity of the approach given the initial and final velocities. Some participants suggest using the equations of motion for constant acceleration, while others express uncertainty about the appropriateness of certain equations in this context.
The discussion includes multiple interpretations of the problem and various approaches to solving it. Some participants affirm the correctness of the original poster's method, while others provide alternative equations of motion. There is a mix of confidence and uncertainty among participants regarding the application of different formulas.
Participants note that the original approach using average velocity is valid, despite concerns about initial conditions and acceleration. There is an emphasis on understanding the conditions under which certain equations apply, particularly in relation to initial velocity and acceleration.
Shahab Mirza
A car traveling with constant acceleration increases its speed from 10 m/s to 50 m/s over a distance of 60 m . how long does this take?
a. 2 seconds b. 4 seconds .
Data :
Avg Velocity = 10 + 50 / 2 = 30m/s
Distance = 60 meter
time = ?
Solution :
S= V x T
making "T" subject . Then
T= S/V
T= 60/30
T = 2 seconds . This Answer is correct , but please tell me that the way I have solved this is correct or not? Thanks
Your solution is fine.
I agree with Doc Al. Your method is correct.
But I'm in a nit picky mood this morning. Use parenthesis in the expression for calculating the average velocity in order to show that the 10 and 50 are added together first before dividing by 2:
( 10 + 50 ) / 2.
Anyway, good work!
Thanks , But I am not satisfied with my solution, u know why sir? because S = vt is possible when initial velocity is 0 means herz equation s = vit + 1/2 a t^2 , but this eq can only be reduced to s =vt when acceleration is unity and initial velocity is 0 , in my case it isn't ? please make me clear or I am going fine?
Check this:
We have three equations of motion for constant acceleration along 1D,
1. v=u+at,
2. v*v - u*u=2as, and
3. S=ut + 1/2at*t
okay
Here u(initial velocity)=10m/s, v(final velocity)=50m/s, a=constant (so apply equations as it is a 1D problem), s=60, t=?
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
Now using this value of 'a' in eq 1 we get;
50=10+20*t
t=2s
Thats it fella...
Physics Newbie said:
Check this:
1. v=u+at,
3. S=ut + 1/2at*t
okay
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
50=10+20*t
t=2s
Thats it fella...
Yes Thanks , this was really a perfect solution , I was wondering how s = vt going to solve this , Thanks a lot
What you're using, whether you realize it or not, is ##\Delta S = v_{ave}t##. Which is fine here.
Thanks , but the sir who replied above gave this solution.
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
50=10+20*t
t=2sI think it was simple nasic problem, I followed question wrong i think.
Top tip:Whenever there is constant acc in 1D go for the equations...
Its very kind of you , Thanks for sharing knowledge , actually I am going to give medical college admission test this year , it has 3 subjects on which test will be based , 1 BIology . 2 Physics 3 Chemistry . so these little concepts will help me a lot , Thanks
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
50=10+20*t
t=2s
There's nothing wrong with this solution, of course. But note the extra steps involved.
Your original approach using average velocity was just fine.
Doc Al said:
There's nothing wrong with this solution, of course. But note the extra steps involved.Your original approach using average velocity was just fine.
Yes I understood Sir , Thanks , I will keep all these things in my knowledge . Thanks
