Moving clock as seen by an observer at rest
  • Context: High School
  • Thread starter Thread starter samirgaliz
    Clock Observer Rest
The discussion revolves around the perception of time as measured by a moving clock in a transparent rocket, as observed by a stationary observer on the ground. It explores concepts of time dilation, the relativistic Doppler effect, and the implications of relative motion on the observation of time intervals, including both theoretical and conceptual aspects.
  • Some participants assert that a moving clock will appear to slow down due to time dilation when viewed by a stationary observer, but the perceived rate depends on the direction of motion relative to the observer.
  • Others argue that the apparent rate of the moving clock is influenced by the relativistic Doppler effect, where a clock moving towards the observer appears to tick faster, while one moving away appears to tick slower.
  • A participant emphasizes that time dilation is frame-dependent, stating that each observer perceives their own clock as ticking normally while observing the other's clock as running slow.
  • Some contributions suggest that the physical observation of the moving clock's rate can be affected by light travel time, leading to corrections in perceived time intervals.
  • There are discussions about whether the stationary observer would see the moving clock running fast or slow at different moments, depending on the clock's position and motion relative to the observer.
  • Participants mention the use of signals (like radio beeps) from the moving clock to illustrate how frequency shifts occur due to relative motion, complicating the perception of time intervals.
  • Some participants express uncertainty about the conditions under which the moving clock might seem to match the observer's clock rate, indicating a need for clarity on specific scenarios.
There is no consensus among participants. While some agree on the principles of time dilation and the Doppler effect, others present competing interpretations of how these effects manifest in observations. The discussion remains unresolved regarding the specifics of how the moving clock is perceived under different conditions.
Participants highlight the importance of accounting for light travel time when interpreting observations, and there are unresolved questions about the implications of different frames of reference and the conditions under which observations are made.
samirgaliz
Please forgive me if this has been asked before. I understand that a clock that is moving relative to an observer at rest will slow down.
If the moving clock is in a transparent rocket, would the stationary observer on the ground see the moving clock slow down physically?
That depends on whether the moving clock is moving towards him or away from him. If the clock is moving towards him, then with every second that passes the clock will be closer, so the light that leaves the clock when it reads 12:00:01 has farther to travel to reach the observer's eyes than the light that leaves the clock when it reads 12:00:02. Thus the time interval between the arrival of the light from 12:00:01 and the arrival of the light from 12:00:02 will be less than the it would be if the clock were not moving - the clock appears fast. If the clock is moving away, it works the other way and the clock appears slow. (This is the relativistic Doppler effect - google will find much more about it).
However, to decide what rate the clock is ticking at you have to subtract out the light travel time. If the clock is three light-seconds away, then the observerknows that the light spent three seconds in flight to get to his eyes, so if he sees it reading 12:08:13 he knows that was what it read three seconds ago. When we make that correction, we find that no matter what we see the moving clock is running slow - this is time dilation.
Just to be sure you are clear about this, let's say that A and B have a velocity of some significant percent of c relative to each other. We choose a frame of reference in which A is at rest and all of the motion is assigned to B. To A, B's clock is running slow but to B his clock is running just fine at one second per second but A's clock is running slow. That is, time dilation never happens to YOU, it is something you perceive to be happening to someone who is moving relative to you.
EDIT: my point is that your statement that the clock "runs slow" is not really correct. What is correct is to say it "runs slow in the frame of reference in which he is at rest (but does not run slow in the frame of reference in which it is at rest)".
@samirgaliz
Perhaps I can help you.
You are on earth, and there's an astronout (male, so I don't have to use his/her) travels and sending signal to you.
If your clock is at 00:00 you receive his signal read 00:00
Your clock is 00:06, his signal read 00:12
Yours is 00:12, his 00:24
Yours His
00:18 00:36
00:24 00:48, etc...
So the rate is 2, let's say k = 2.
His proper time runs faster than yours??
So he must be traveling toward you.
Can you work out how fast he travels (speed = v)?
Remember to calculate his proper time is yours * gamma
Gamma is Lorentz Factor
##\gamma = \sqrt{1-v^2}##
His distance is receding over time.
So when his distance is at VT he sends you his clock reading
##t-vt = kt\sqrt{1-v^2}##
##1-v = k\sqrt{1-v^2}##
##(1-v)(1-v) = k^2(1-v)(1+v)##
##k^2 = \frac{(1-v)(1-v)}{(1-v)(1+v)}##
##k = \sqrt{\frac{(1-v)}{(1+v)}}##
Now if I see
this looks like doppler equation?
Solution
##v = -0.6##
Hi moves toward you
I interpret "The moving clock in a transparent rocket" is the clock fixed in a moving transparent rocket.
You are turning your head and arm to keep watching the clock to compare with your watch.
Pushing away tedious changing consumed times for light to travel from the clock to his eyes, the stationary observer on the ground see the moving clock slow down physically. Furthermore the pilot see the observer's watch slow down physically.
And you believe that this physical observation that both clocks are seen to slow down holds when the two are moving towards each other at a substantial fraction of c?
I believe so, the direction of motion does not matter. I would be glad if you put me on a right understanding.
No need to observe a clock on a transparent rocket with a telescope or something.
You could set a clock on the rocket to send a radio beep once every second, yet it would appear to be a slower rate as received by the stationary observer.
Really? Even if the ship is traveling towards you at .5c? You think the beeps would be MORE than 1 second apart?
See post #9
I think what would happen is that the 'raw data' would show a higher frequency, but that data would be blue shifted.
After manipulating the signal so that it corresponds to the known/designed radio frequency of the beep, it would look slower.
But we were talking about exactly the situation where you do not do any manipulations, you just go with what you see (or hear in the case of radio beeps) --- see post #5. You are positing a different process so naturally you are getting a different answer. Let's answer one question at a time.
Changing the question, if the moving clock is in a transparent rocket, would THE STATIONARY OBSERVERS on the ground see the moving clock slow down physically?
The answer is Yes. Tom reported the rocket clocks was adjusted when it passed by him, Dick reports the rocket clock is delayed now it is passing by. Direction of motion does not matter with slowness.
Back to the original question, Tom, the only observer, should watch rocket at least twice when the distances between him and the rocket differ. Travel time of light, i.e. he see here now is what happened such a place in such a past time, and Doppler effect affects his sight perception.
samirgaliz, would you go this way?
The stationary observers would see the moving clock running fast when it was moving towards them and running slow when it was moving away. Only after they corrected for the light travel time would they calculate (not "see", but "calculate") that the clock was runnings slow all along.
You are right. I should have written explicitly that the observers can observe rocket only when it passes by. They do not observe ( or at least do not report about ) the distant rocket.
To test my understanding, is there a moment that the clock in the approaching rocket, not in just adjacent nor leaving position, SEEMS to have the same pace with the observer's watch ? I suppose "Yes".
So you are considering the relativistic Doppler effect as the passing rocket approaches, passes nearby and then recedes. The moving clock is first seen to be ticking rapidly as it approaches and later seen to be ticking slowly as it recedes. You ask whether there is a point (or an angle) where the moving clock can be seen to be ticking at its normal rate. The answer is, of course, "yes". The tick rate will be seen to vary continuously throughout the exercise. If it starts fast and ends slow, there must be a point where it is ticking normally. This is the intermediate value theorem for continuous functions.
Thanks for your interest. The point is it happens before the rocket reaches the observer, before the rocket is adjacent to him or pass over. How about it?
Taking the point of view of the observer, it is clear that the Doppler contribution to the frequency will be zero at the point of closest approach. Near that point the transit time for light from rocket to observer will be nearly unchanging. So as the rocket is seen to reach its closest approach, the rocket clock rate that is seen will only be affected by relativistic time dilation. It will be seen to tick slowly.
Accordingly, the point where it is seen to tick normally must be prior to that.
Edit: By the time this is seen to happen, the rocket will "currently" be somewhat farther along in its journey. But I do not think you are asking about that.
Thanks again for your investigation including Edit. The observer sees that the clock that ticks normally has not reached the closest point to him. That would be an alternative statement.
Thanks to everyone who clarified this. My assumption is when the observer on the ground observes the moving clock in the rocket at the closest point, ignoring approaching or departing. That is ignoring Doppler effect.
So this brings me to my next dilemma!
If the observer on the rocket measures the half life of radioactive material to be "to" using his clock. The observer at rest on the ground will also see the moving clock with the recording time "to" and thus sees the radioactive material decays at half life "to". But we also know that the observer on the ground will measure the half life of the moving radioactive material as measured by his clock to be t >to.
So it seems like there is a contradiction for the observer on the ground! He will think that his clock is wrong since physically he observes the radioactive material decays in a time "to"!
Maybe I am going into a circular argument. My apologies!
Radioactive decay would behave as any other kind of clock.
Both the static observer and the moving observer would measure the same half life for their own sample.
Yet both would observe the other person's sample as decaying more slowly than their own.
As rootone says, radioactive decay is a kind of clock. It runs slow if it is moving. The dilation of the half-life of muons was one of the first tests of relativity, in fact.
That won't work. To determine if a clock is running slow you need at least two events, with some way to measure the time that elapses between the events. What you describe is a single event. All you could do with that is determine any difference between clock readings, which would tell you nothing about any differences that might exist between the rates at which the clocks are running.
But that showing of a higher frequency in the data is what we call the blue shift!
The ground observer ground will see the moving radioactive material decay at a rate that matches the time on the moving clock, not his own. This will be the case both for what the observer SEES (faster when approaching and slower when moving away because of the Doppler effect) and for what the observer CALCULATES (after allowing for light travel time affecting when the light hits our eyes, we find that the movingclock is always running slow relative to our own).
We could even dispense with the clock and use the radioactive matter as a clock instead: if the half-life of the radioisotope in question were one second as measured by an observer at rest relative to a sample of it, then we have a "clock" that ticks off the passage of one second every time that that the intensity of the radiation is reduced by one-half. In fact, any time-dependent process - the graying of the traveller's hair, paint drying, the decreasing length of a burning candle (people really did use that to tell time once)... - can be used as a clock.
Not each single event for a observer, but integrated information of multiple events from the observers reveals slowness of the clock.
We do not have to hire many observers Should synchronized clocks be set everywhere, an observer can see the clock in the rocket also see the clock set there and compare them. He see the rocket now and then and find various time differences that show the slowness of the clock in the rocket.
As well as the term mass, when we refer decay time, the material should be at rest. The moving radioactive material has another (prolonged) value of decay time.
Thank you everyone! things are much clearer to me now.
What do you mean it should be at rest? EVERYTHING is at rest in one frame and everything is moving in another frame.
We should choose the frame where referred body is at rest and measure decay time in that frame. Thus observed value is "decay time".
  • · Replies 16 ·
  • · Replies 53 ·
  • · Replies 33 ·
  • · Replies 25 ·
  • · Replies 84 ·
  • · Replies 16 ·
  • · Replies 21 ·
