Fortran How to Retrieve the Value of MPI_TAG_UB in openmpi/2.1.1 Using Fortran?
  • Thread starter Thread starter pachomba
    Fortran
The discussion revolves around retrieving the MPI_TAG_UB parameter using OpenMPI version 2.1.1 with Fortran. The user initially attempts to use the MPI_COMM_GET_ATTR routine but encounters errors related to undeclared parameters and linking issues. A key suggestion is to include "use mpi" at the beginning of the Fortran code to access MPI constants. The user later successfully compiles the program using mpifort instead of gfortran, which resolves the linking problem. However, they face a runtime error related to shared memory and are advised to use a parallel launcher like mpirun for execution. Additionally, it is noted that the program lacks output statements to display the value of MPI_TAG_UB, and there is a correction regarding the number of arguments in the MPI_COMM_GET_ATTR call, as well as clarification on the expected value of MPI_TAG_UB, which should be at least 32767, not 7.
pachomba
Hello,
I am trying to get the parameter MPI_TAG_UB for openmpi (I am using version 2.1.1). I know I need to use the routine MPI_COMM_GET_ATTR, but I have no idea how to do that, I never used fortran in my life. Following this link (https://www.mpi-forum.org/docs/mpi-2.2/mpi22-report/node369.htm) I tried this:
LOGICAL FLAG
INTEGER IERR
INTEGER (KIND=MPI_ADDRESS_KIND) VALUE
! Upon successful return, VALUE == 7 (sign extended)
CALL MPI_COMM_GET_ATTR(MPI_COMM_WORLD, KEYVAL, VALUE, FLAG, IERR)
I put that in a file test.f90, then did gfortran test.f90 -o test.out, but I got this error message:
Error: Parameter 'mpi_address_kind' at (1) has not been declared or is a variable, which does not reduce to a constant expression
Error: Unexpected end of file in 'test.f90'
So I have no idea what I'm doing. Did someone ever retrieved the value of MPI_TAG_UB for some MPI implementation?
Thanks!
Technology news on Phys.org
MPI constants are of course not part of Fortran, so the compiler doesn't know what to do with MPI_ADDRESS_KIND.
Try
Fortran:
use mpi
at the beginning of your code.
Try
Fortran:
use mpi
Thank you very much DrClaude, I tired that and I got this error:
Then I tried including "PROGRAM test" and "END PROGRAM test" at the beginning and end of the script, and I got this error:
~/tmp/cc3b6Lod.o: In function `MAIN__':
test.f90:(.text+0x34): undefined reference to `mpi_comm_get_attr_'
collect2: ld returned 1 exit status
I know it must be a very basic thing I'm not doing, I plan to learn some fortran in the future but for now I just need to get that MPI_TAG_UB value.
Truly appreciate any help.
That's because your not linking to the MPI library. The easiest way to do this is to compile using mpifort instead of gfortran (it will still use gfortran, but will correctly link). See https://www.open-mpi.org/faq/?category=mpi-apps
Thank you Dr, I was able to compile the program with mpifort, now the program looks like this:
PROGRAM test
include 'mpif.h'
LOGICAL FLAG
INTEGER IERR
CALL MPI_INIT(IERR)
CALL MPI_COMM_GET_ATTR(MPI_COMM_WORLD, MPI_TAG_UB, MAXTAG, VALUE, FLAG, IERR)
END PROGRAM test
but when I run it I get this error now:
shmem: posix: file name search - max attempts exceeded.cannot continue with posix.
I guess I need to add an include 'something' line at the beginning? Also, is this going to actually tell me what the value of MPI_TAG_UB is?
pachomba said:
PROGRAM test
include 'mpif.h'
LOGICAL FLAG
INTEGER IERR
CALL MPI_INIT(IERR)
END PROGRAM test
That program has no output. you have to add a print (or write) statement to show the value of VALUE. Also, when posting code, please use CODE tags (you can get them automatically by clicking on the + in the bar above the text area and choosing </> Code.)
This appears to be an implementation-dependent error. How are you launching the program? (Often, you need a launcher to execute correctly in parallel, such as mpirun.)
As I wrote above, the program as is will have no output. Looking at the specification soft MPI_COMM_GET_ATTR, you have one argument too many. You should remove MAXTAG. Also, I don't understand why you think that VALUE should be 7, because the MPI standard specifies that the upper bound on tags is never smaller than 32767.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 22 ·
