Multiple angles : Reducing the sum
11 replies · 2K views · last reply
brotherbobby
Show that ##\large{\boxed{\tan\theta+2\tan 2\theta+4\tan 4\theta+8 \cot 8\theta = \cot\theta}}##
1. ##\tan 2\theta = \frac{2\tan\theta}{1-\tan^2\theta}##
2. ##\tan 4\theta = \frac{4\tan \theta-4\tan^3 \theta}{1-6\tan^2\theta+\tan^4\theta}## (borrowed from a problem that asked to prove as much).
3. ##\tan 8\theta =?, \cot 8\theta = ?## (No readymade equations available)
Problem Statement :
Let me copy and paste the problem as it appears in the text :
Attempt : I haven't been able to make any significant attempt at solving this problem, am afraid. I tried to reduce all the higher submultiple angles ##2\theta, 4\theta, 8\theta## into ##\theta##, but the resulting equation became unwieldy.
Request : As I have failed to do my fair share, the barest of hints to start me off would be welcome.
##tan(8\theta)= tan(2(4\theta))##. You can apply the double angle formula, and then use your known result for the quadruple angle.
##cot(8\theta)=1/tan(8\theta)## so once you know one you know the other.
I don't know if this is the best way to go about this but at least you can give it a shot now.
@brotherbobby, where are you?
Here is a slightly different hint.
See what you can do with ##\displaystyle \tan(\phi) + 2 \cot(2 \phi) ## .
Once we see some workings from you, you may expect some additional suggestions.
Another way to attack the problem is using complex exponentials. Start with
$$\tan \phi = \frac{1}{i} \frac{e^{i\phi}-e^{-i\phi}}{e^{i\phi}+e^{-i\phi}} = \frac{1}{i} \frac{e^{2i\phi}-1}{e^{2i\phi}+1} = \frac{1}{i} \frac{z-1}{z+1},$$ where ##z=e^{2i\phi}##. You can express the other terms in the identity in terms of ##z## as well. Then do a lot of algebra.
Hello @Office_Shredder and @SammyS, thank you for your help and sorry for coming in late. I will solve the problem using two methods, neither of them mine. I will use @vela 's method later (post #6 above).
Problem statement : ##\large{\boxed{\tan\theta+2\tan 2\theta+4\tan 4\theta+8 \cot 8\theta = \cot\theta}}##.
First Attempt (brute force) : I will paste my solution done using Autodesk Sketchbook##^{\circledR}##. I hope I am not in violation of something.
Second attempt (elegant) : ##\text{What is} \tan\theta-\cot\theta##? I will derive an expression for this and then use it to do the problem above.
##\tan\theta+2\tan 2\theta+4\tan 4\theta+8 \cot 8\theta = \cot\theta ##
Let's look at the following part of your Second Attempt.
So, if you had taken my suggestion in Post #5, the above shows that you could have found that:
##\displaystyle \tan(\phi) + 2 \cot(2 \phi) = \cot( \phi )##.
Then use this result recursively, starting with the last two terms on the left hand side of your original expressions.
Use ##4\theta## in place of ##\phi## and you get:
##\displaystyle 4(\tan(4\theta) + 2 \cot(2 (4\theta) ) )= 4\cot(4\theta)##
Repeat using suitable replacement for ##\phi##.
I'll warn you that it's a lot of tedious algebra. It may not be worth solving the problem this way except perhaps to satisfy your curiosity.
Yes @SammyS, the method you had suggested is close to the second of my attempts above. Thank you. To be honest, it is @vela's method that interests me at the moment. I'd like to try it presently.
As @vela said, it can involve a lot of tedious algebra.
However, using it to show your result (1) may be enough to satisfy your curiosity.
##\displaystyle \cot( \phi ) - \tan(\phi) = 2 \cot(2 \phi) \quad ## (1)
No worries, we are young people, hungry to know. Curious as hell.
Third Attempt (using complex numbers) ​
[Prelude to complex numbers : I remember from school days that the complex number ##z## can be written in the "rectangular" and "polar" forms in the following way : ##z=x+iy=re^{i\theta}## where ##(x,y)## are the rectangular co-ordinates of the complex number and ##(r,\theta)## its polar co-ordinates. We can go from ##(x,y)\rightarrow (r,\theta)## using ##r=\sqrt{x^2+y^2}## and ##\theta=\tan^{-1}\frac{y}{x}## and in the reverse direction ##(r,\theta)\rightarrow (x,y)## using ##x=r\cos\theta,\; y =r\sin\theta##. Thus the complex number can be written as ##z=r(\cos\theta+i\sin\theta)##. If ##r=1##, ##z=\cos\theta+i\sin\theta=\boldsymbol{e^{i\theta}}##, given without proof. Hence, we have ##e^{-i\theta} = \cos\theta-i\sin\theta##. Through adding and subtracting, we can find that ##\cos\theta = \frac{e^{i\theta}+e^{-i\theta}}{2}## and ##\sin\theta = \frac{e^{i\theta}-e^{-i\theta}}{2i}##. Upon dividing the two, ##\tan\theta = \dfrac{e^{2i\theta}-1}{i(e^{2i\theta}+1)}=\frac{z-1}{i(z+1)}##, where ##z=e^{2i\theta}##. And upon multiplying both top and bottom by ##i^2=-1##, we get ##\boxed{\tan\theta=\dfrac{i(1-z)}{z+1}}##. Likewise ##\boxed{\cot\theta = \frac{i(z+1)}{z-1}}##. ]
Problem attempt : In view of the exponential nature of ##e^{2i\theta}=z\Rightarrow z^2=e^{4i\theta}## and beyond, we have the three terms on the left hand side of our equation as ##\tan 2\theta=\dfrac{i(1-z^2)}{z^2+1}##, ##\tan 4\theta = \dfrac{i(1-z^4)}{z^4+1}## and ##\cot\theta=\dfrac{i(z^8+1)}{z^8-1}##.
However, in light of the above post #11 by @SammyS, I am going to be satisfied if I can prove that ##\cot\theta-\tan\theta = 2\cot 2\theta##. From the results above, we have $$\boldsymbol{\cot 2\theta = \dfrac{i(z^2+1)}{z^2-1}}... (1)$$.
L.H.S. = ##\cot\theta-\tan\theta = \dfrac{i(z+1)}{z-1}-\dfrac{i(1-z)}{z+1}=\dfrac{i(z+1)^2+i(z-1)^2}{z^2-1}=\dfrac{2i(z^2+1)}{z^2-1}=2\cot 2\theta##, in light of (1) above.
