Multiple in logarithm question -- find the variable?
16 replies · 3K views · last reply
Helly123
$$ \log_{x} a \ means \ 10^x = a $$
$$ \log_{x} {a^n} = n \log_{x}{a} $$
$$ \log_{10} {ax} \log_{10}{bx} + 1 = 0 $$
$$ \ means \log_{10} {ax} = 1 \log_{10}{bx} = -1 \ or \ vice \ versa $$
$$ \ for \log_{10} {ax} = 1 \ so \ ax \ = 10 \ and \ \log_{10}{bx} = -1 \ so \ bx \ = 0.1 \ or \ vice \ versa $$
bx/ax = b/a = 0.1/10 = 0.01
or b/a = 10/0.1 = 100
so b/a > ?
how to make range for b/a ? how's the correlation with x?
No, not true. It just means that ##\log_{10}(ax)\cdot \log_{10}(bx) = -1##. For example, one could be 1/2 and the other could be -2.
Work from this equation, and use the fact that ##\log(mn) = \log(m) + \log(n)##.
I haven't worked the problem, but this is what I would do.
so b/a > ?
What's the formula for ##\log (p \cdot q)##? And what do you get, if you apply it to ##\log(ax)\cdot \log(bx)##
so b/a > ?
No, ##\log_x a## does not mean ##10^x = a##; it means that ##y = \log_x a## is the solution of the equation ##x^y = a##.
Anyway, your "solution" is all wrong; you are assuming things that need not be true.
Using the standard result that ##\log_{10}(ax) = \log_{10} a + \log_{10} x##, etc., will help.
ok, i get
(loga + log x) . (logb + log x) = -1
$$ \log_{10}{a} . \log_{10}{b} + 2\log_{10}{x} = -1$$
Helly123 said:
ok, i get
Still wrong. Check your algebra.
Oh
.. Loga.logb + (logx)^2 = -1
Helly123 said:
ok, i get
Let's make it easier and forget about the logarithms for a moment. Say ##a_l = \log a\, , \,x_l = \log x \; , \;b_l=\log b##.
Now what is ##(a_l + x_l) \cdot (b_l +x_l) + 1 = 0\,##?
Helly123 said:
Oh
Are you working things out in detail, or are you just guessing? (Because you still have not gotten it right, although you are getting a bit closer.)
ab + x(a +b) + x^2 + 1 = 0
loga . log b + logx(log a + log b) + (logx)^2 + 1 = 0
Yes, and now solve this equation and consider especially the sign of the two solutions and the expression under the root.
Helly123 said:
I still don't get it. Can anyone give me hint?
It's a quadratic equation with ##log(x)## as the variable. Use the quadratic formula!
let's say I want to solve the equation ab + x(a +b) + x^2 + 1 = 0
using abc formula : { -(a+b) +- root [ (a+b)^2 - 4(ab + 1) ] } / 2
{-a-b +- root [ a^2 + b^2 - 2ab -4 ] } /2
what am I suppose to do next?
root1 * root2 = c/a
root 1 + root 2 = -b / a
so,
root 1 * root 2 = c/a = { ab + 1 } / 1 = loga + log b + log 10
what to do to find root 1 and 2 which is contains log a and log b and contains a and b?
You are supposed to figure out what the condition that at least one root is > 0 has to say about a and b.
If there is going to be a solution then the quantity in the square root needs to be nonnegative. Write down that condition and see if you can simplify it.
