Multiplication of incompatible matrices
This discussion centers on the multiplication of incompatible matrices in the context of finite element formulations. User Hamid Attaran presents a scenario involving matrices of dimensions 8x2, 2x2, 2x4, 4x1, and 2x8, which cannot be multiplied due to incompatibility. Participants suggest alternative approaches, including defining a new multiplication method, embedding matrices into square matrices, or utilizing the Kronecker product as a solution for combining these matrices effectively.
  • Understanding of matrix dimensions and compatibility
  • Familiarity with finite element methods
  • Knowledge of tensor products and Kronecker products
  • Basic linear algebra concepts
  • Research the properties and applications of the Kronecker product
  • Explore methods for embedding matrices into square matrices
  • Study alternative multiplication definitions for non-compatible matrices
  • Learn about the role of tensors in finite element analysis
Mathematicians, engineers, and researchers involved in finite element analysis, matrix algebra, and tensor calculus will benefit from this discussion.
attaran
Dear members,
I have a rather silly question.
As we all know only the compatible matrices can be multiplied. My derivation of some Finite Element formulation has, however, led me to the multiplication of two incompatible matrices.
I was wondering if we could make these incompatible matrices, compatible by some factorization techniques. Has anyone ever encountered such a problem?
I appreciate if someone could help me in this respect.
Regards,
-- Hamid Attaran
Hey attaran and welcome to the forums.
Can you provide more information? What dimensions are the matrices? Are the matrices special types? (Like diagonal, triangular, singular, non-singular, have specific determinant, eigenvalues, eigenvectors and so on)
Thanks for your reply, Chiro.
Some are diagonal and some are not.
For one case I have reached from:
[A]8x2.2x2.[C]2x4.[D]4x1.[E]2x8
to:
[]8x1.[]2x8
which obviously are not compatible for matrix multiplication.
These are populated as follows:
A = [A11 0
0 A22
0 A82]
B = [B11 0
0 B22 ]
C = [C11 C12 C13 C14
C21 C22 C23 C24]
D = [D11
D21
D31
D41]
E= [E11 0 E13 0 ... E17 0
E21 0 E23 0 ... E27 0]
I hope I have provided enough information.
regards,
-- Hamid
to:
[]8x1.[]2x8
A = [A11 0
0 A22
0 A82]
B = [B11 0
0 B22 ]
C21 C22 C23 C24]
D = [D11
D21
D31
D41]
regards,
-- Hamid
Well, either (1) you define a new multiplication between non-compatible matrices, or (2) you embed all your matrices into
one single set of square matrices, perhaps by adding zeros to their rows or columns, or (3) you plainly cannot multiply those matrices among them.
I wonder why you think, or feel, that you must multiply those matrices...?
DonAntonio
The point is that if your method arrives at the multiplication of two "incompatible" matrices, then this cannot be ordinary multiplication of matrices. How you would alter the usual definition of multiplication of matrices would depend upon what you want this multiplication to mean. And that can only be determined by the precise problem you are dealing with.
Most likely you have got confused about something.
Computer programs for the finite element method often store data in 2-d arrays which are NOT "matrices" in the mathematical sense. For example the 6 independent compoents of a symmetric 3x3 tensor (for eaxmple stress and strain) are often stored in a 6x1 vector. Or 21 independent constants for an arbitrary anisotropic material might be stored in a symmetric 6x6 matrix, when it is really a 3x3x3x3 fourth-order tensor with a large number of symmetry relations between the 81 terms.
DonAntonio, HallsofIvy and AlephZero, Thanks for your comments and help.
As I was discussing my problem with a mathematician, he advised me to use the "Tensor Product" instead and after a quick survey, looks like that I can use a special case of tensor product, called "Kronecker product". According to Wikepedia(en.wikipedia.org/wiki/Kronecker_product)
"If A is an m-by-n matrix and B is a p-by-q matrix, then the Kronecker product A ⊗ B is the mp-by-nq block matrix ".
Thanks and regards,
-- Hamid
  • · Replies 25 ·
