Multiquote failing across pages in the same thread
  • Context: Bug
  • Thread starter Thread starter symbolipoint
24 replies · 3K views
Homework Helper
Education Advisor
A topic in a forum covering two forum pages will fail to allow multiquote from more than one of the pages.
On my android phone Chrome browser, it works properly. In a single thread, I can easily quote messages from multiple pages and put them in together. I have made a screen video and will post it as soon as it's uploaded to YouTube.
Update: the screen video is below:-
Edit: Changed media.
Poor video, post #2. Actions taken poorly resolved. Use of the multiquote buttons not visible. No such Insert Quote button found in the compose field of forum.
I believe I have now resolved a user-mistake. Not sure. Use of Multiquote button then requires the use of the Reply button, for posts in either pages of the thread.
WRONG! I just tried again and Multiquote from different pages of a thread still fails.
Works for me. What exactly do you do and what exactly is the result you get?
Click on "+Quote" on a post on one page, then go to a different page, click on "+Quote" on another post. Then click on "insert quotes" on the lower left. You can even quote across threads that way.
All this needs JavaScript enabled, but that is true even if you don't change pages.
I have changed the media. Hope it's better this time. At the end, you will find four quoted messages, three from first page and one from the next.
I gave up on the "Quote" "Multi-Quote" feature a while back, but maybe it works better now. I just use the Reply feature, and if I need to include quoted things from multiple pages, I use Reply to the stuff on one page, cut it into the clipboard, go to the next page and paste it in at the bottom of the page in the Reply window, and keep on Reply/quoting the stuff on the 2nd page. A little clunky, but works every time for me.
Odd; I can report an opposite problem: How to flush unwanted quotes.
Suppose I +quote a few lines from posts in thread A, decide not to use it and move on to thread B where I want to +quote different posts. How do I clear the "quote buffer"?
  1. log out;log back in.
  2. insert holdover quotes in reply buffer than erase.
  3. use reply key for first quote in thread B.
Solutions 1 & 2 are cumbersome, while 2 is also tedious. Three works as reply first flushes or overwrites the buffer but leads to @berkeman 's fix:
I think you can go back and click the Quote link again to reset it (the little plus sign comes back, like +Quote)
But like I said, I gave up using Quote a long time ago, so maybe that's not how it works now. o0)
Just click on "Insert Quotes" near the reply box. You will see an option to remove quoted messages. It will be in blue:
Works fine for me. I grabbed quotes from 3 diff pages of a many many page thread and it worked just fine. I didn't do the final posting step but you can see that they multi quotes are there in the created reply. I've sped up the time so that the video is only 30 seconds.
All that is a very different process. I will have to try it (later).
phinds,
Your video of post #11 did not finish so I cannot see the rest of the process.
symbolipoint said:
phinds,
Do you mean what I stated?
I didn't do the final posting step ...
No, that is the multi-quote feature.
If you talk about something else, see above: What exactly do you do, what result do you expect and what do you get?
@symbolipoint There seems to be some confusion regarding which feature you are calling "multiquote". @phinds, @mfb and I have tried to convey the same thing, which you term:
Why don't you post a screen video showing what you are trying to do? That will remove any confusion.
( I am going to try to put in these few consecutive screen shots, might itself be difficult to figure how...)
( No. Not now. I need to use a URL for this instead of just giving them from the local computer here. I will describe the process of try to multiquote without first showing any images.)
Taking for example, The coming revolution in physics education,
https://www.physicsforums.com/threads/the-coming-revolution-in-physics-education.954664/
Several forum pages hold the topic's discussion.
Let me try to multiquote posts #2, #21, and #42
which are respectively on page 1, page 2, and page 3.
METHOD:
  1. Page 1, clicked in post #2, Multiquote button; then clicked Reply
  2. Page 2, in post #21, clicked Reply
  3. Page 3, in post #42, clicked Reply
RESULT:
All THREE posts are shown quoted displayed in the composition field.
I do not know why I was seeing failures before. I will just need to keep reviewing this and checking what happens in future multiquote attempts.
The topic is not yet resolved for me until I no longer find failures in my multiquote attempts.
symbolipoint said:
METHOD:
That's not the correct method.
Step 1: Either click "+ Quote" at the bottom right of the 1st message you want to quote
Or select some text and click "+ Quote" below
Step 2: Repeat step 1 for each message you want to quote.
Step 3: Go to the text box at the bottom of the thread and press the "INSERT QUOTES..." button in the bottom left corner
METHOD:
RESULT:
As @DrGreg has said above, you were not using the multiquote feature at all. When you clicked on the "Reply" option, the message was quoted in the Reply box, and given some time, the server automatically saved the draft. Previously, when you were doing the same, you were not giving enough time for the server to save the draft, and that is why you were unable to see the message when you moved on to a different page.
You may follow what @DrGreg has said, or you can continue your process, but just remember to manually save the draft before you move on to the next page. Just click on the save option:
and you will see an option to save the draft:
It's not the "multi-quote" feature, but it is an alternative method.
As @Wrichik Basu noted, it is a question of the draft of your reply being saved or not. There is an automatic save, so it is a question of the time between when you hit reply and when you go to the next page. If the automatic save doesn't have time to quick in, then when you click "next page" the reply box will be empty.
:oldbiggrin: ...
The topic "Got my BS in Physics but I don't know what to apply for", https://www.physicsforums.com/threa...-what-to-apply-for.963457/page-2#post-6122105
post #38, although the topic itself is still ONE single page;
Multiquote was used.
I believe some of the advice her is helping.
Method was:
  1. highlight desired text, click the item MultiQuote
  2. highlight another desired text, click the item MultiQuote
  3. Scroll to the composition field, find the button, Insert Quotations, and click the Post button
So far this appears successful.
symbolipoint said:
Post #21 and #21 22
How did you do that? Attachments?
Yeah... screen shots using the Snipping Tool.
