Multivariable temperature variation while swimming in a hot spring
11 replies · 2K views
Poetria
You are swimming along the surface of a large natural hot water spring. The temperature is hottest near the geothermal heat sources, and cools off inversely proportional to the distance from the heat source as you move away. The hot spring you have found has two heat sources. One is located below x=0, y =0, the other is located x=-10, y=20
Approximation of the temperature:
##T(x,y) = \frac {450} {\sqrt{x^2+y^2+1}}+\frac {420} {\sqrt{(x+10)^2+(y-20)^2+1}}##
You enter the pool at the edge x=20, y=20, where the temperature is 30 degrees Celsius.
What is the gradient of the temperature?
$$\nabla (\frac {450} {\sqrt{x^2+y^2+1}}+\frac {420} {\sqrt{x+10)^2+(y-20)^2+1}})$$
I have computed
##T_x## and ##T_y## and evaluated it at the point (20, 20).
## \frac {-450*x}{x^2 + y^2 + 1)^(\frac {3} {2}} - \frac {420*(x + 10)} {(x + 10)^2 + (y - 20)^2 + 1)^(\frac {3} {2}}, \frac {-450*y}{x^2 + y^2 + 1)^(\frac {3} {2}} - \frac {420*(y - 20)} {(x + 10)^2 + (y - 20)^2 + 1)^(\frac {3} {2}}##
I got [-0.8628, -0.3970]. But it is not correct.
So the answer to the next question: At what rate does the temperature rise per unit distance in that direction?
is not correct:
-2.1732 degrees per meter
Poetria said:
Homework Statement:: You are swimming along the surface of a large natural hot water spring. The temperature is hottest near the geothermal heat sources, and cools off inversely proportional to the distance from the heat source as you move away. The hot spring you have found has two heat sources. One is located below x=0, y =0, the other is located x=-10, y=20
I don't think the formula for [itex]T[/itex] is correct. Was that given in the question, or did you have to derive it yourself?
This formula was given. I have checked it once more. What's wrong with this equation?
I get the same formula for the gradient, but a different value at (20,20). I get (-0.3745, 0.749). Can you check that calculation? I am not completely confident in my calculations.
Of course. Still the same:
-0.862892919050474097014734857686704644880586505653053268225642320
-0.397002951313243437752836778926172651474292918967096802620165023
Perhaps there is a mistake in my formula you haven't noticed. Weird anyway.
I rechecked my calculations and got the same answers you got. (I made reasonable assumptions about some missing parenthesis in the gradient in your post #1.)
Thank you very much. :) I need more practice with Latex.
I can't understand why it's marked as wrong. :(
I have decided to continue with the next part of this exercise and it turned out that the value -0.862892919050474097014734857686704644880586505653053268225642320
should be rounded -0.8629 while I have given -0.8628.
And of course the result: -2.1732 degrees per meter is not correct.
It's the gradient's length as the slope of a tangent plane: 0.9498.
Thanks once more for your patience. :)
Yes. I think that your initial value had a little more precision than required. ;-)
  • Haha
I'm curious about what tools you used to do your calculations to that precision.
I agree with the vector ##(-0.8628,-0.3970)## for gradient, I calculated it using wolfram.
However the answer to the second question is simply the magnitude of the gradient vector. I don't understand how you calculated -2.1732 degrees per met.
I have used Wolfram Alpha.
