Mutual effects of gravity and velocity on time
The discussion confirms that all clocks on the geoid, which is defined as an equipotential surface in a rotating frame, run at the same rate due to the interplay of General Relativity and Special Relativity. Gravity is stronger at the poles, but this effect is balanced by the velocity at the equator, maintaining synchronicity of clocks across the Earth's surface. Tidal forces from the sun and moon have a negligible impact on this phenomenon. The analysis relies on the conservation of energy principle within static geometries.
  • Understanding of General Relativity and its impact on time perception
  • Familiarity with Special Relativity and its effects on velocity
  • Knowledge of equipotential surfaces in physics
  • Basic principles of energy conservation in physics
  • Explore the implications of General Relativity on time dilation in rotating frames
  • Study the concept of equipotential surfaces and their relevance in gravitational fields
  • Investigate the effects of tidal forces on timekeeping and gravitational theories
  • Learn about energy conservation principles in General Relativity and their applications
Physicists, students of theoretical physics, and anyone interested in the relationship between gravity, velocity, and timekeeping on Earth.
Dmstifik8ion
The Earth takes the shape of an oblate spheroid due to its rotation and so gravity is stronger at the North/South Poles while the Equator has a velocity relative to the Poles.
When we consider General Relativity (the effect of gravity on the passage of time) together with Special Relativity (the effect of velocity on the passage of time) do these effects precisely cancel out maintaining synchronicity of clocks over the surface of a rotating oblate spheroid?
Dmstifik8ion said:
The Earth takes the shape of an oblate spheroid due to its rotation and so gravity is stronger at the North/South Poles...
Don't be so quick to assume that gravity is greater at the poles because of the smaller radius. I believe this is false.
Basically, the answer is yes. All clocks on the geoid run at the same rate. See for instance http://www.physicstoday.org/vol-58/iss-9/p12.html or http://hermes.aei.mpg.de/2003/1/article.xhtml (it's a long article, see the section above (21)).
This ignores tidal forces from the sun and moon, which have only a very small effect. (The effect does perturb the theoretical ideal, i.e. it hasn't been included in the above analysis).
One can derive this if one assumes that energy is conserved. The geoid is defined to be an equipotential surface in the rotating frame. Therfore, if energy is conserved, light measured in the rotating frame should have the same energy if it starts and stops at any two equipotential points, i.e. there should be no net red or blueshift between any two points on the geoid.
Energy conservation in GR can get tricky, but as long as one sticks to static geometries this argument works fine.
Thanks, the links are perfect!
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 18 ·
  • · Replies 58 ·
  • · Replies 18 ·
  • · Replies 23 ·
