My answer:y=az^by=19.7(.454z)^0.753
  • Context: MHB
  • Thread starter Thread starter arl2267
    Functions Nonlinear
The basal metabolic rate (BMR) for large anteaters is defined by the equation y = 19.7x^0.753, where x represents the anteater's weight in kilograms. For anteaters weighing 5 kg and 25 kg, the calculated BMR values are 66.19 kcal/day and 222.39 kcal/day, respectively. To convert the weight from pounds to kilograms, the function x = g(z) = z * 0.454 is established, where z is the weight in pounds. The BMR can then be expressed in pounds by substituting this function into the original equation, resulting in y = a * z^b, where a is derived from the conversion factor.
  • Understanding of basal metabolic rate (BMR) calculations
  • Familiarity with weight conversion between pounds and kilograms
  • Knowledge of function composition in mathematics
  • Basic algebra for manipulating equations
  • Study the implications of weight on metabolic rates in different species
  • Learn about function transformations and their applications in biology
  • Explore the relationship between weight and energy expenditure in animals
  • Investigate the use of dimensional analysis in biological equations
Biologists, zoologists, and students studying animal physiology, particularly those interested in metabolic rates and weight-related calculations in animals.
arl2267
The basal metabolic rate (in kcal/day) for large anteaters is given by:
y=f(x)= 19.7x0.753
where x is the anteater's weight in kilograms
a) find the basal metabolic rae for anteaters with the following weights
i. 5kg
ii. 25kg
My answer:
i= 66.19kg
ii= 222.39 kg
Hopefully I got a right, but b and c I need some help with please.
b) suppose the anteater's weight is given in pounds rather than kilograms. Given that 1lb=.454kg, find a function x=g(z) giving the anteater's weight in kg if z is the animals weight in lb.
c) write the basal metabolic rate as a function of the weight in pounds in the form y=azb by calculating f(g(z)).
Mathematics news on Phys.org
Your answers are correct thus far, the new function of kg to pounds is found by multiplying through by $\frac{1}{0.454}$
