My simple proof of x^0=1 part 2 (axioms)
The discussion centers on the proof that \( x^0 = 1 \) for \( x \neq 0 \) using axioms from Walter Rudin's "Principles of Mathematical Analysis." The proof leverages axioms (M3) and (M5), specifically focusing on the properties of multiplication in a field. The author establishes that \( x^0 \) can be derived from the commutative property of multiplication and the existence of multiplicative inverses, concluding that \( x^0 = 1 \) holds true in any field for non-zero \( x \).
  • Understanding of field axioms, particularly (M3) and (M5) from abstract algebra.
  • Familiarity with exponentiation and its properties in mathematics.
  • Knowledge of basic mathematical analysis concepts as presented in Walter Rudin's texts.
  • Comprehension of the implications of defining operations in extended number systems, such as the Riemann sphere.
  • Study the axioms of fields in detail, focusing on the implications of (M3) and (M5).
  • Explore the concept of exponentiation in various mathematical contexts, including natural numbers and fields.
  • Investigate the properties of the Riemann sphere and its treatment of division by zero.
  • Examine the definitions and implications of \( 0^0 \) in different mathematical frameworks.
Mathematicians, students of abstract algebra, and anyone interested in the foundational principles of exponentiation and field theory.
why Fenix
I was looking for explanation why x^0=1.
thread
https://www.physicsforums.com/threads/my-simple-proof-of-x-0-1.172073/
is locked and i did't found solution in it from axioms. People using exp(x) and log(x) and xa-a=xax-a as given.
If you have xa-a=xax-a for a∈ℤ and x∈ℕ+ then there is no question... (thank to M5 below...)But from axioms ... maybe something like this?...:Starting from "Principles of mathematical analysis. Walter Rudin" page 5 and 6.
For any field F we get axioms:
"(M3) Multiplication is commutative: xy=yx for all x,y ∈ F"
"(M5) If x ∈ F and x ≠ 0 then there exists an element 1/x ∈ F such that
x⋅(1/x) =1." Let assume (Rudin does not specify that) that we call this element x-1.
On next page (6) Rudin in Remark 1.13 states:
"One usually writes (in any field) ...x2, x3... "
"in place of ... xx, xxx, ..."
Let assume (Rudin does not specify that) that x=x1.
From (M5) we get
1=x⋅(1/x) =x1x-1
so
1=x1x-1 ⋅ 1 = x1x-1 ⋅ x1x-1 = (from M3) = x1⋅x1⋅x-1⋅x-1=(from remark 1.13)=
x2⋅x-1⋅x-1.
But we got for x2 from (M5)
1=x2(x2)-1
we get (not proving that if ab=c and ad=c then b=d)
x-1⋅x-1=(x2)-1=(from now on)=x-2 let's call this (equation 1). Now we know what x-n is.
(from remark 1.13) where ∏kX=X⋅X⋅...⋅X k-times
XA+B=∏A+BX=∏AX⋅∏BX=XA⋅XB
so
XA+B=XA⋅XB and A,B ∈ℤ base on (equation 1)
If A=1 and B=-1 we get from above
XA+B=XA⋅XB=X1⋅X-1=(from M5 only for X≠0)=1
and
XA+B=X(1)+(-1)=X0
we get X0=1for X≠0 because of (M5) (we don't know what 0-1 is...)
the end ...
and now just for fun :)
00=(1-1)1-1=(1-1)1(1-1)-1=(0)1(1-1)-1=0⋅(1-1)-1=0/(1-1)1=0/(0)1=0/0
so
00=0/0
thread
From (M5) we get
1=x⋅(1/x) =x1x-1
so
x2⋅x-1⋅x-1.
1=x2(x2)-1
so
and
XA+B=X(1)+(-1)=X0
we get X0=1for X≠0 because of (M5) (we don't know that 0-1 is...)
the end ...
No, this isn't valid, but maybe you don't seriously mean it. If you do mean it, though, in the second factor you have essentially 0-1. M5 applies only if x ≠ 0.
so
00=0/0
Mark44 said:
...don't seriously mean it...
Yes. Proof is finished on "the end...".
I was just trying too write something funny in the end of the post... :)
But now I wonder.
Let us assume that we are in Riemann sphere or just ℂ∪{∞} and (M5) is given for (X=0) by 1/0=∞.
Of course ∞=z*∞=z*1/0=z/0.
and now we will get 00=0/0 (of course we don't know what 0/0 is but is equal to 00 from axioms ).
why Fenix said:
But now I wonder.
From the Wiki article on the extended real numbers, http://en.wikipedia.org/wiki/Extended_real_number_line :
"The expression 1/0 is not defined either as +∞ or −∞..."
In the Riemann sphere, 0/0 is left undefined for a reason. If you define it and if you allow yourself to do algebra with it, you are begging for trouble.
In the two point compactification of the real number line, 1/0 is left undefined. In the one point compactification of the complex plane, it is defined. However... http://en.wikipedia.org/wiki/Riemann_sphere: "The quotients 0/0 and ∞/∞ are left undefined."
As I said. We are not in real numbers or extended real numbers.
But in ℂ∪{∞} or something like Riemann sphere.
Here http://en.wikipedia.org/wiki/Riemann_sphere you can find "...The extended complex numbers are useful in complex analysis because they allow for division by zero in some circumstances, in a way that makes expressions such as 1/0 = ∞ well-behaved..."
There is
+∞∉ ℂ∪{∞}
-∞∉ ℂ∪{∞}
∞∈ ℂ∪{∞}
But neither ##0/0## or ##0^0## are defined on the Riemann sphere
When you start from axioms and wonder about x0=1 you can show that x0=1 for x≠0 because of (M5). (As I did in my first post above.)
So when you extend (M5) with (1/0)=∞, like it is done in Riemann sphere, you should get what x0 for x=0 is.
Thanks to (M5) with (1/0)=∞
for x=0 we get from (M5) 0*(1/0)=1
and from (1/0)=∞ and above we get 0*∞=1.
and because 0 is inverse to ∞ so we will put 1/∞=0
now from (M5) we get ∞(1/∞)=1.
Is this a field?? What will break ?? Which axiom ?? We need just one or we will get 0*(1/0)=0/0=1.
List of axioms from http://math.elinkage.net/showthread.php?tid=102
A field is a set F with two operations addition and multiplication, satisfying axioms (A),(M) and (D):
(A) Axioms for addition
(A1) Addition is closed in F: (x,y∈F)⇒(x+y∈F)
(A2) Addition is commutative: x+y=y+x(∀x,y∈F)
(A3) Addition is associative: (x+y)+z=x+(y+z)(∀x,y,z∈F)
(A4) F has additive unit: ∃0∈F∀x∈F0+x=x
(A5) F has additive inverse:∀x∈F∃−x∈F(x+(−x)=0)
(M) Axioms for multiplication
(M1) multiplicationis closed in F: (x,y∈F)⇒(xy∈F)
(M2) multiplication is commutative: xy=yx(∀x,y∈F)
(M3) multiplication is associative: (xy)z=x(yz)(∀x,y,z∈F)
(M4) F has multiplicative unit: ∃1∈F∀x∈F1x=x
(M5) F has multiplicative inverse:∀x∈F∃1/x∈F(x(1/x)=1)
(D) The distributive law: x(y+z)=xy+xz(∀x,y,z∈F)
The Riemann sphere is not a field because the multiplication is not always defined. Specifically, something like ##0\cdot \infty## is not defined.
It shouldn't be a field. And ##\frac{0}{0}=1## shouldn't be allowed. Indeed, because if it is, then
1 = \frac{0}{0} = \frac{2\cdot 0}{0} = 2\frac{0}{0} = 2
and thus ##1=2##, which should definitely be false.
yes, you are right.
1 = 0/0 = ((1+1) * 0)/0 = (1+1)*(0/0) = (1+1) and would be 0=1.
and we got zero ring...
http://en.wikipedia.org/wiki/Zero_ringBut main thing in this post is the proof that x^0=1. for x≠0. In any field. Is it good?
why Fenix said:
yes, you are right.
That ##x^0 = 1## is essentially a definition. While your proof is good it requires:
1) That ##x^0## exists
2) That ##x^{-1}## exists
3) That the usual law ##x^{a+b} = x^a x^b## is satisfied
Ad.2. For x≠0 we get from (M5) that ##x^{-1}## exists.
Ad.1. I think i will get it from 3)
Ad.3. Is given for positive natural a,b, in Remark 1.13. For negative a,b we can get it from remark 1.13 and (equation1 --- x-1x-1=x-2
extended to (k-times)
x-1x-1⋅...⋅x-1 =x-k).
Now we can take integers "a" positive, "b" negative.
And knowing that xa and xb well defined ( as remark o_O )
we get that xa+b for integers "a" positive, "b" negative is equal to xa⋅xb ...Extention of the definision?? Remark ?? o_O Wishful thinking?o:) Or just notation? Let's go with Extention of Remark 1.13.From one side if a+b>0 then we say that xa+b=xc for some positive c.
other side if a+b<0 then we say that xa+b=xc for some negative c.
so we need 1)?
for b=-a and (M5) we would get xa+b=xa+(-a)=xax(-a)=xa(1/xa)=(M5)=1
and we get xa+(-a)=x0 so exists 1) ??
It does not look professionally.
So in any field we have to add to axioms remark about notation like this?
a∈ℤ.
xa=xa+1/x
x0=1
or
a∈ℤ.
xa=xa+1/x
x1=x
  • · Replies 0 ·
