Narrow Width Approximation for a spin 1 resonance
In summary, the conversation discusses the treatment of the sum over spin polarizations when using the Narrow Width Approximation (NWA) with a spin 1 resonance. The focus is on the decay of a top quark via a W boson, where the aim is to understand how the decay width can be factorized into the production and decay of a real W boson. The conversation includes a detailed explanation of the amplitude and polarization vectors involved, and ultimately concludes with a question on how to show that the squared amplitude can be written in a factorized form.
jkp
Hi
I'm trying to understand how the sum over spin polarizations is treated when using the Narrow Width Approximation(NWA) with a spin 1 resonance. For a spin zero resonance there is no such problem and the factorization is quite straightforward. I'll go through some details to explain where my problem is.
It'll be easier to talk about a specific example so I'm going to look at the decay of a top quark via a W boson, which is a spin 1 resonance. The decay follows like this ##t(k)\to b(p_1) W^*(q) \to b(p_1) f(p_2) \overline{f}'(p_3)## where ##f## and ##f'## are any fermion. So we'd expect that close to the resonance peak we can factorize the width as
$$\Gamma(t\to b f \overline{f}')=\Gamma(t\to b W) BR(W\to f\overline{f}')$$
that is the production and decay of a real W. My aim is to understand how this factorization occurs here for a spin 1 resonance.
Starting from the decay width formula we have,
$$\Gamma_{t\to b f\overline{f}'}=
\frac{1}{2 m_{t}}\frac{1}{2}\sum_{spin}
|{\mathcal M}(t\to b f \overline{f}')|^2
dLIPS$$
where
$$dLIPS
\frac{d^3 \vec{p}_{1}}{2 E_{p_1}(2\pi)^3}
\frac{d^3 \vec{p}_{2}}{2 E_{p_2}(2\pi)^3}
\frac{d^3 \vec{p}_{3}}{2 E_{p_3}(2\pi)^3}
(2\pi)^4 \delta^4(p_1+p_2+p_3-k)$$
is the lorentz invariant phase space.
So my first job is to factorize the amplitude into ##t\to b W## and ##W\to f\overline{f}'## parts. We can write the amplitude as,
$${\mathcal M}(t\to b f \overline{f}')=
{\mathcal M}_1^\mu
\,\frac{(-g_{\mu\nu}+q_\mu q_\nu / M_W^2)}{q^2-M_W^2+iM_W\Gamma_W}
\,{\mathcal M}_2^\nu
{\mathcal M}_1^\mu
\,\sum_\lambda \frac{\epsilon^*_\mu(q,\lambda)
\epsilon_\mu(q,\lambda)}
\,{\mathcal M}_2^\nu$$
where ##{\mathcal M}_{1,2}## come from the ##t-b-W## vertex and ##W-f-f'## vertex respectively and I've used the polarization sum over the W polarization vector identity, ##\sum_\lambda \epsilon^*(q,\lambda)\epsilon(q,\lambda)=(-g_{\mu\nu}+q_\mu q_\nu/M_W^2)##, in the second equality where ##\lambda## is the W polarization. To simplify the notation I'm going to define as follows,
$${\mathcal M}^\lambda_{t\to b W}=
{\mathcal M}_1^\mu \epsilon^*_\mu(q,\lambda)$$
and
$${\mathcal M}^\lambda_{W\to f\overline{f}'}=
{\mathcal M}_2^\mu \epsilon_\mu(q,\lambda)
So the amplitude becomes,
\sum_\lambda
\frac{{\mathcal M}^\lambda_{t\to b W}{\mathcal M}^\lambda_{W\to f\overline{f}'}}
Now squaring the amplitude we have,
$$|{\mathcal M}(t\to b f \overline{f}')|^2
\left|\sum_\lambda
{\mathcal M}^\lambda_{t\to b W}{\mathcal M}^\lambda_{W\to f\overline{f}'}\right|^2
\frac{1}{{(q^2-M_W^2)^2+M_W^2\Gamma_W^2}}
And this is where I get stuck. The propagator part is easy to deal with in the NWA it will change to a delta function like this,
\frac{1}{{(q^2-M_W^2)^2+M_W^2\Gamma_W^2}}\to
\frac{2\pi\,\delta(q^2-M_W^2)}{2M_W^2\Gamma_W^2}
but I'm not sure how to deal with the square of the polarization summed amplitude,
$$\left|\sum_\lambda
Ideally I want to show that this can be written as something like,
\left(\sum_\gamma\left|{\mathcal M}^\gamma_{t\to b W}\right|^2\right)
\left(
\frac{1}{3}\sum_\lambda \left|{\mathcal M}^\lambda_{W\to f\overline{f}'}\right|^2
\right)
so that the decay width will factorize into, ##\Gamma(t\to b f\overline{f}')=\Gamma(t\to b W)BR(W\to f\overline{f}')##.
So my question is how do I show that, ##\left|\sum_\lambda
\left(
\right)
I'm sorry for all the details but I wanted to give the full context of my question.
Thanks
this is most probably the nifty trick of avoiding polarization.You should have written those λ's explicitly.
|Mμε*λμελvMv|2=(1/3)Ʃλ1,λ2|Mμε*λ1μ|2λ2vMv|2
the factor of 1/3 arises because you must sum over the final spin states and take an average over initial spin states after summing it(i.e. divide by 3 for W Boson).
Thanks for the reply Andrien but maybe you can provide a little more detail. I don't understand how you get ##\lambda_1## in one bracket and ##\lambda_2## in the other. As far as I see it we have,
\left| \sum_\lambda
{\mathcal M}_1^\mu \epsilon^{\lambda *}_\mu
\epsilon^\lambda_\nu {\mathcal M}_2^\nu
\right|^2
\left(\sum_\lambda{\mathcal M}_1^\mu \epsilon^{\lambda *}_\mu
\epsilon^\lambda_\nu {\mathcal M}_2^\nu\right)
\left( \sum_\gamma{\mathcal M}_1^\rho \epsilon^{\gamma *}_\rho
\epsilon^\gamma_\sigma {\mathcal M}_2^\sigma\right)^*
=\sum_\lambda \sum_\gamma
({\mathcal M}_1^\mu {\mathcal M}_1^{\rho *}
\epsilon^{\lambda *}_\mu \epsilon^{\gamma}_\rho)
({\mathcal M}_2^\nu{\mathcal M}_2^{\sigma *}
\epsilon^\lambda_\nu \epsilon^{\gamma *}_\sigma)
here we still have ##\lambda## and ##\gamma## in each of the brackets. This needs to be factorized so that there is ##\lambda## in one of the brackets and ##\gamma## in the other bracket as you wrote in your reply.
I could switch the polarization vectors so that we have,
=\left(\sum_\lambda {\mathcal M}_1^\mu {\mathcal M}_1^{\rho *}
\epsilon^{\lambda *}_\mu \epsilon^\lambda_\nu\right)
\left(\sum_\gamma{\mathcal M}_2^\nu{\mathcal M}_2^{\sigma *}
\epsilon^{\gamma}_\rho \epsilon^{\gamma *}_\sigma\right)
but now the lorentz indices don't match up within the brackets!
So how do I take the final step?
It seems to me that I need some identity for the polarization vectors such as the following,
\varepsilon_\mu^{\lambda_1 *}\varepsilon_\nu^{\lambda_2}
=\delta^{\lambda_1\lambda_2}\frac{1}{3}
\left(\sum_\lambda \varepsilon_\mu^{\lambda *}\varepsilon_\nu^{\lambda} \right)
that is, the product of two polarization vectors is zero if the polarizations are different and equal to 1/3 the sum over polarizations if the two polarizations are equal. Does anybody know if such an identity actually exists?
No,the square of the modulus is just extra complication.It has nothing to do with it.It is used in all decay processes where you don't observe the final polarization states.you just sum over the final spin states and take an average over the initial spin states after summing over initial spin states.There is no use of any identity.It is the usual way.since W boson has 3 spin states,you will have to divide by three.In electron scattering you divide by two after summing because of two polarization possible like here in mott scattering on page 203-204
http://books.google.co.in/books?id=lvmSZkzDFt0C&pg=PA137&dq=sakurai+advanced+quantum+mechanics+coulomb+scattering&hl=en&sa=X&ei=1-v_UIjSLIjMrQfYoIH4BA&ved=0CEEQuwUwAw#v=onepage&q=sakurai%20advanced%20quantum%20mechanics%20coulomb%20scattering&f=false
also see here eqn. 3
http://arxiv.org/abs/0807.4112(see the full paper):smile:
Thanks again Andrien
From the reference you provide I now see that the Narrow Width Approximation isn't just that the propagator becomes,
but also that we must approximate,
\left|\sum_\lambda
\to
\left(
\right)
So this second transformation isn't an exact equality as I had assumed in my original question but a further simplification of the NWA proceedure.
sure,it is a simplification which is done to avoid polarization.
Related to Narrow Width Approximation for a spin 1 resonance
1. What is the Narrow Width Approximation for a spin 1 resonance?
The Narrow Width Approximation (NWA) is a commonly used approximation in particle physics to simplify the calculation of scattering amplitudes for particles with a short lifetime or a narrow width. It assumes that the resonance has a small width compared to its mass, allowing for the simplification of the calculation to include only the dominant contribution from the resonance.
2. How is the Narrow Width Approximation used in particle physics?
The NWA is used in particle physics to simplify calculations involving resonances with a short lifetime or a narrow width. It is commonly used in the analysis of high-energy collisions at particle accelerators, such as the Large Hadron Collider (LHC), to study the properties of new particles that may have a short lifetime.
3. What are the limitations of the Narrow Width Approximation?
The NWA is only valid for particles with a short lifetime or a narrow width, and may not accurately describe the behavior of particles with a longer lifetime or a wider width. Additionally, it does not take into account any contributions from higher-order processes, which may affect the accuracy of the approximation.
4. How does the Narrow Width Approximation impact the analysis of experimental data?
The NWA is often used in the analysis of experimental data to simplify the interpretation of the results and to extract information about the properties of new particles. However, it is important for scientists to carefully consider the limitations of the NWA and to also perform calculations using other methods to validate the results.
5. Can the Narrow Width Approximation be applied to all spin 1 resonances?
No, the NWA is only applicable to spin 1 resonances with a short lifetime or a narrow width. Other methods, such as the Breit-Wigner formula, may be used to calculate scattering amplitudes for particles with a longer lifetime or a wider width.
  • High Energy, Nuclear, Particle Physics
