Natural Frequency of Stepped Shaft
The discussion focuses on determining the natural frequencies of pressure rakes modeled as cantilevered beams with varying cross-sections. Participants suggest using hand calculations alongside numerical models to confirm results, emphasizing the importance of matching boundary conditions. Key references include Timoshenko's "Vibration Problems in Engineering" and a specific paper by Yu and Cleghorn on the free vibration of spinning stepped Timoshenko beams. The conversation highlights the need for accurate calculations to avoid resonance issues in operational ranges.
  • Understanding of cantilever beam dynamics
  • Familiarity with Timoshenko beam theory
  • Knowledge of torsional and lateral vibration analysis
  • Proficiency in calculating equivalent spring constants
  • Research the calculation of natural frequencies for cantilever beams with varying cross-sections
  • Study Timoshenko's "Vibration Problems in Engineering" for detailed methodologies
  • Explore the paper by Yu and Cleghorn on spinning stepped Timoshenko beams for advanced insights
  • Investigate methods for matching boundary conditions in vibration analysis
Mechanical engineers, vibration analysts, and researchers involved in the design and analysis of dynamic systems, particularly those working with stepped shafts and cantilever beams.
minger
Hi guys, I need to find the natural frequencies of a series of pressure rakes. We have a numerical model, but I'd like to confirm with a hand calculation. I would like to model the pressure rakes as a cantilevered beam with varying cross section (i.e. as each tube "stops" the beam decreases in area).
I looked on Ohiolink for journal articles and through Timoshenko's Vibration Problems in Engineering but can't come up with anything. If anyone has an article, or a link somewhere I would appreciate it. Thansk,
Your best bet is to plink them. That's what I do. You can get in the area or do a numerical analysis, but it is very difficult to match the boundary conditions they actually see. This way you will get the exact natural frequencies from a quick test that is easy to do.
Well we're designing them. Ideally we wouldn't want to buy a set, then find out that the parts we just bought have natural frequencies that cross certain excitation lines in our range of operation.
Either way it might be a good idea to plink them after we receive them, but I'd like to have an idea of their response before.
If I remember correctly you can treat a stepped shaft as a set of torsional springs arranged in series. Have a look at the first chapter of Vibration Problems in Engineering, by Weaver, Timoshenko and Young. I'm pretty sure it covers it in there.
I 'think' I seen what you are thinking of, but IIRC it didn't quite apply to me. Let me see if I can find it.
Yea,
If the shaft consists of two parts having lengths l_1 \,\mbox{and}\, l_2 with diameters d_1\, \mbox{and}\, d_2, the separate torsional constants may be calculated from eq. (c).
k_r = \frac{GJ}{l} = \frac{\pi d^4 G}{32l}
The equivalent spring constant can then be obtained from eq. (k)
k_{eq} = \frac{k_1 k_2}{k_1 + k_2}
OK, so this directly applies to torsional vibration, but I can assume it applies to lateral as well. If so, then how can I calculate equivalent spring constants for the bar?
Would the individual spring constants simply be a long bar, with several hollow cylinders?
For lateral vibration can't you treat it as a series of masses rotating on a shaft, but with mass and stiffness distributed over the same area? Try a later chapter in that book (or any in the series)...I think it's chapter 5.
Edit: try finding the following paper if your subscription covers it - the approach and references should give you some help.
Yu, S.D. and Cleghorn, W.L.
Free Vibration of a Spinning Stepped Timoshenko Beam
J. Appl. Mech. -- December 2000 -- Volume 67, Issue 4, 839 (3 pages)
DOI:10.1115/1.1331282
  • · Replies 22 ·
10K
55K
