Navier Stokes Equations - General Question
The Navier-Stokes equations incorporate both pressure and gravity terms to accurately represent fluid dynamics, particularly in geophysical contexts. The pressure term accounts for forces due to fluid density and temperature variations, while the gravity term represents the body force acting on the fluid. These terms cannot be combined because they represent different physical phenomena; pressure forces drive fluid motion, while body forces like gravity indicate potential energy differences. Understanding this distinction is crucial for analyzing fluid behavior in systems with varying altitudes and densities. The momentum equation illustrates this balance by equating changes in momentum to the sum of pressure, viscous, and body forces.
gilgtc
(This is from the perspective of Geophysical Fluid Dynamics)
In the Navier Stokes equations I am confused as to why there is both a pressure term and a gravity term. Is this pressure resulting from differences in densities and temperature differences alone? I would think that the gravity term would be lumped into the pressure term. Can someone please clarify?
I am sorry if this makes no sense I am just trying to understand,
Thanks for your help.
g
Engineering-wise a look into energy balance is always comfortable. If in the system there are two distinct bodies of fluid, having same velocity, density, pressure and temperature, but at different altitudes, the system still has the energy potential to do something. If the gravity term would be missing from Navier-Stokes equations, then they would not show this potential.
Chusslove Illich (Часлав Илић)
gravity is usually shown for the body force component. However this can also be centrifugal force etc.
the pressure term should be for the pressure force driving the fluid. In compressible flow this is the same pressure that change with temperature and density. The body force is of different nature. It cannot be lump into the pressure term. Perhaps because all terms on RHS are forces, and this gives you the impression that they can be lump together. In fact, they are different.
the momentum equation:
Change of momentum = pressure force + viscous force + body force
My idea is that I want to use immerse Whitetail Antlers in a fishtank to measure their volumetric displacement (the Boone and Crockett system is the current record measurement standard to place in a juxtaposition with) I would use some sight glass plumbed into the side of the tank to get the change in height so that I can multiply by the tank cross-section. Simple Idea. But... Is there a simple mechanical way to amplify the height in the sight glass to increase measurement precision...
  • · Replies 18 ·
