How Does the Boundary Layer Simplify the Navier-Stokes Equations?
  • Thread starter Thread starter member 428835
    Navier-stokes
The discussion focuses on the simplification of the Navier-Stokes equations within a boundary layer context, specifically analyzing the significance of the x-component of the Laplacian, \(\frac{\partial^2 u}{\partial x^2}\). Participants confirm that in boundary layer analysis, where the vertical displacement \(\delta\) is much smaller than the horizontal length scale \(L\), the term \(\frac{\partial^2 u}{\partial x^2}\) can be considered negligible due to its order of magnitude. Furthermore, it is established that outside the boundary layer, this assumption remains valid under consistent flow and geometry conditions.
  • Understanding of Navier-Stokes equations
  • Familiarity with boundary layer theory
  • Knowledge of partial derivatives in fluid dynamics
  • Basic concepts of flow over flat plates
  • Study the implications of boundary layer thickness on fluid flow
  • Learn about the Prandtl boundary layer theory
  • Explore the significance of the Reynolds number in boundary layer analysis
  • Investigate the effects of varying flow conditions on the Navier-Stokes equations
Fluid dynamics engineers, researchers in aerodynamics, and students studying advanced fluid mechanics will benefit from this discussion.
member 428835
hey pf!
so i have a question concerning navier-stokes equations in a boundary layer, which, as a refresher, is \frac {D \vec{V}}{Dt} = - \nabla P + \nu \nabla^2 \vec{V} where we know the x-component of \nabla^2 \vec{V} may be re-wrote as \frac{\partial^2 u}{\partial x^2}+\frac{\partial^2 u}{\partial y^2} (i dismiss the z component due to two dimensions). define the vertical displacement as \delta and the horizontal length scale as L
okay, now for the question: we know \frac{\partial^2 u}{\partial x^2} disappears, as it is not of much importance via order of magnitude. my question is, in boundary layer analysis, is this true from the fact that \delta < L \implies \delta^2 << L^2 and thus the \frac{\partial^2 u}{\partial x^2} component can be thought of as insignificant (from the large denominator) compared to the \frac{\partial^2 u}{\partial y^2} component?
if so, when we leave the boundary layer are we going to assume that the double partial over x is still insignificant, or are we allowed to assume this (assuming same flow and geometry, just outside the BL)
thanks!
Uhhh, it would be nice to have a figure of what your system is or some kind of information describing what's going on in your system. You can't always say that (d^2u/dx^2) is 0. If du/dx is constant or weakly dependent on x, then you may make that assumption.
Can I assume y is the direction to and from a plate, and x is the direction along the plate? So, that would seem the most logical to me. I'm not sure if the u velocity varies linearly inside the boundary layer or not, I honestly don't remember, it's been a while. However, outside of the boundary layer you can definitely assume the second derivative in the x direction is 0. That is, assuming flow on a plate as I described.
  • · Replies 0 ·
