Understanding Relativity: How Moving Objects Experience Near Light Speed Travel
Space travel at light speed is impossible for objects with mass, as increasing velocity requires exponentially more energy. While current engineering cannot achieve near light speed for spacecraft, theoretical principles suggest it is not entirely impossible. The cosmic microwave background (CMB) poses significant challenges, including blueshift effects and particle production, which complicate acceleration to high velocities. Discussions indicate that while achieving speeds close to 0.999999991c is theoretically conceivable, practical limitations render it unfeasible with existing technology.
  • Understanding of Einstein's theory of relativity
  • Familiarity with cosmic microwave background (CMB) radiation
  • Knowledge of particle physics and energy requirements for acceleration
  • Basic principles of thermodynamics in high-energy environments
  • Research the implications of the cosmic microwave background on high-speed travel
  • Explore advanced propulsion systems capable of near light speed travel
  • Study the effects of relativistic speeds on material properties and particle production
  • Investigate current advancements in particle accelerators and their energy limits
Physicists, aerospace engineers, and anyone interested in the theoretical and practical aspects of high-speed space travel and the challenges posed by relativistic physics.
  • #61
fresh_42 said:
What do you expect? Shall I read it for you? I gave a proper link and the page.
I read the referenced pages and didn't find anything that supports your claim. But I at least agree with you that somebody did not understand the references.
fresh_42 said:
The rocket is the issue. We have low energy photons and high energy electrons and protons in that collision.
In the rest frame of the rocket we have IR radiation of an 8.6 K black body as well as protons and electrons almost at rest. We would have a major problem if that could result in pair production.
  • #62
fresh_42 said:
Given that, the only question remaining is: at which rocket speed?
Exactly. And other people have been trying to calculate that. I don't see any justification for you simply dismissing their calculations.
The only number you have given is 5 J; I gave you the gamma factor for 5 J. Have you calculated what relative velocity that equates to? It's certainly not 0.8 c. It's not even the number @vanhees71 gave in post #59; it's even closer to ##1## than that. And the closer to ##1## the relative velocity is, the less relevant it is since it would take a longer and longer trip (assuming constant proper acceleration all the way) for the ship to reach such a high gamma factor.
  • #63
How much energy is necessary to accelerate, say 1 ton of mass from 0.8c to .81c? O.k. I can do the math, but let's assume for a moment, that this is enough to create particles. If there is a possibility of such a creation, then it will take place. As said from the beginning, inverse Compton was a guess of mine which looked plausible. So assumed that this amount of energy is produced somewhere in the ship, then there will be a particle creation, which in return means it cannot be used for acceleration anymore.
  • #64
Just to give you an idea of the company you are in here:
https://www.physicsforums.com/threa...bject-goes-near-of-the-speed-of-light.982767/
And he ended up writing a crackpot paper overturning SR and GR. Turn back before it's too late :wink:
  • Haha
  • #65
Again, you seem to be confusing total energy with energy per particle. The energy per particle at these speeds is much, much less than that required for particle creation.
If total energy were all that were required, we would have had massive pair production when, for example, the Saturn V rockets were launched to take the Apollo astronauts to the Moon.
  • #66
fresh_42 said:
Still better than some guys on the internet.
You're one of those guys, and I think it's very disrespectfull to treat every single person here that way. Especially ones that showed numerous times that they know what they are talking about.
  • #67
Yes, Compton seems to be off the table. But I still do not see, that Lesch was wrong. The fact that it was on youtube does not make it wrong per se. He is yet an active ordinary professor in theoretical physics at an ordinary German university. Sorry, but it is in the nature of the question here that sound calculations on this topic are hard to find. If we travel at 0.8c and have a interaction surface of 1 sq.mtr. then we will collide with 96,000,000,000,000,000 photons per second at 0.8c, and this shouldn't create resistance?
(Assuming 400 CMB photons per ##cm^{-3}## is correct.)
  • #68
I don't think anyone is arguing that Lesch was wrong in what he said. I think people are saying that what he said does not support what you are saying.
Radiation pressure should be easy to calculate. But radiation pressure is not what you appear to be talking about.
  • #69
He isn't wrong. What you are reading into that video is wrong.
It creates resistance. But 1 pN/m² radiation pressure is not worth mentioning. If I got the numbers correctly it is 13 orders of magnitude below the drag of the interstellar medium.
  • #70
This is what I actually said:
fresh_42 said:
Reason why it won't work either way: CMB will work as resistor and additional energy meant for acceleration will be turned into particle production instead and arbitrarily close to c will be physically impossible, regardless which engine we constructed.
which is what Lesch said, and my post here was:
fresh_42 said:
It was on a tv show, so no valid reference. At least it was an astronomer who said it. The photons of the CMB are everywhere, so there will be no way to escape them. They make space a fluid with viscosity. Thus depending on mass and surface area we will get a thermodynamic effect. I don't know at which temperature particle production begins, and whether it is pair production, or radioactivity due to collisions with the ship's material, or due to the existing matter in space.
My suspicion: inverse Compton effect.
The closest I could find:
https://arxiv.org/pdf/astro-ph/0106530.pdf
Comments:12 pages, 4 figures, in press
Subjects:Astrophysics (astro-ph)
Journal reference:Astropart.Phys. 17 (2002) 347-354
DOI:10.1016/S0927-6505(01)00156-6
Cite as:arXiv:astro-ph/0106530
And of course, there are no scientific papers of rockets at near c speed.
  • #71
You said pair production "arbitrarily close to c". But it's quite possible to make interstellar trips without getting "arbitrarily close to c". So even if pair production is physically possible "arbitrarily close to c", that doesn't mean it's actually relevant for interstellar trips. Which is what other people have been pointing out, but you don't seem to be agreeing with them.
Other than pair production, you have mentioned inverse Compton effect and vague handwaving about "viscosity". But Lesch isn't saying either of those things.
In other words, people are pushing back against the Lesch reference because you appear to be claiming that Lesch said something that was relevant to interstellar trips, which, as above, does not appear to be the case.
  • #72
See Lesch's paper in post # 70 on extragalactic jets.
  • #73
Plenty of posters here are perfectly capable of making reasonable estimates--several of them have done just that in this thread. But you have not. You have simply thrown around names of possible effects--pair production, inverse Compton effect, "viscosity"--without making any attempt that I can see to estimate how relevant they are for the gamma factors expected for interstellar trips. And the references you have pointed to, to the extent they give numbers, give numbers that appear to make the claimed effects irrelevant for interstellar trips.
For example:
fresh_42 said:
See Lesch's paper in post # 70 on extra gallactic jets.
The energy per particle in these jets, from what I can see, is in the range ##10^{18}## to ##10^{21}## eV (p. 6). Which, given a proton rest mass of about ##10^9## eV, gives gamma factors of ##10^9## to ##10^{12}##--again, irrelevant to interstellar trips.
So, again, you are getting pushback because none of the references you give seem to be saying anything that is relevant to interstellar trips.
  • #74
I can only assume that Lesch generalized the results of this paper to rockets near the speed of light. This makes a barrier of 0.99995c according to Wikipedia. So it is higher than I thought, but it is an upper bound below c.
  • #75
I've battled my way through the video (he speaks German so clearly that I can actually follow what he's saying). He does claim that you can't get to Andromeda in 28 years proper time. He talks about the increasing radiation pressure, but then a secondary effect kicks in: the high-energy-cosmic ray "speedlimit", which he described as a "wall" where pair production takes place.
The main issue with this is that by the above calculations, the pair production kicks in at speeds far in excess of what is needed to get to Andromeda in approximately 28 years.
We could do a calculation for a proton at this threshold energy, which is ##5 \times 10^{19}eV##, a gamma factor of ##5 \times 10^{10}##. Such a proton would travel the ##2.5 \times 10^6## light years to Andromeda in a proper time of a fraction of a year.
To be fair to @fresh_42, I think Professor Lesch ought to check the numbers for the trip to Andromeda.
PS I think the 28 years is an acceleration and deceleration trip to Andromeda. If you have a proper acceleration of ##g##, then you may reach the pair production gamma factor after 28 years. I haven't got time to check the calculation now.
That might explain the confusion and where the 28 years comes from and how a trip to Andromeda got mixed up in this.
  • #76
What Wikipedia reference are you talking about here? The only Wikipedia references I see in this thread are to the article on UHECRs, which gives energies like ##10^{18}## eV and above, which correspond (for protons) to gamma factors of ##10^9## and above, which correspond to relative velocities much closer to 1 than 0.99995c.
  • #77
That was a quick search for the speed of extragalactis jets. It is probably too high. The paper says
The hadronic jet constituents can efficiently be accelerated in such fields all along the jets. To estimate the maximum energy the accelerated jet hadrons can achieve we consider energy loss processes as photon-pion and pair production as well as synchrotron and inverse Compton radiation.
So I looked up whether those jets are comparably fast to that of an hadronic spacecraft .
  • #78
I would say more like "definitely too high"; a trip anywhere in our galaxy, or even to the Andromeda galaxy, as @PeroK has pointed out, won't get you anywhere near the gamma factor involved with those jets.
  • #79
I just checked it and it is indeed 28 years with 1 g proper acceleration. In a Newtonian universe I would get 3100 years (Lesch says it would be 2800 years). That's pretty much the message of the first part: The cosmic speed limit is our friend and not the problem.
Than he switches to the blue-shifted CMB radiation and pair production at very high speeds (with high-energy-cosmic rays as a real-world example for particles with sufficient speed). But he doesn’t say that it happens in case of the 28 year trip to Andromeda. In this special case I get a gamma factor of 1,300,000 and the maximum of the CMB radiation would be blue-shifted to "just" 3.3 keV. That is well below the limit of 1.022 MeV for pair production.
Thus, the video is correct, but it might be misleading because Lesch doesn’t say that it takes much longer trips for the effect to become a problem. He also didn't mention temperature and radiation pressure as a problem. In case of the trip to Andromeda it would be up to 7 million K and 500 GPa. That means there is no material that could survive and it would take 150 EW/m² just to keep the speed constant.
The resistance starts long before paar production becomes relevant. I'm not even sure if something special happens when it starts. Maybe it is just another way to waste energy.
  • #80
I think this is the root of the confusion.
If we take a proper acceleration of ##g## for 14 years proper time, then we travel about ##1.2## million light years (half way to Andromeda), reach a speed of about ##(1 - \epsilon)c##, where ##\epsilon = 3 \times 10^{-13}##, with a gamma factor of about ##1.2 \times 10^6##, boosting the CMB to X-rays at about ##4 \times 10^{17}Hz##
A trip to Andromeda, where the second half was a deceleration at ##g## would then take 28 years, and the maximum CMB would be X-Rays
If, instead, we keep accelerating at ##g## then we reach Andromeda in less than 15 years proper time and still have no more than CMB X-rays.
But, if we keep accelerating at ##g## for 23 years, then we reach a gamma factor of about ##5 \times 10^{10}##, which boosts the CMB to gamma rays, and the pion pair production problem, associated with the GZK limit for cosmic ray protons. The distance traveled in this case is about ##1.5 \times 10^{10}## light years, i.e. more than the diameter of the observable universe.
As far as I can see from these calculations, the GZK limit is not a problem for getting to Andromeda in 28 years, but it becomes a problem to overcome if you want to accelerate at ##g## for 20+ years.
  • #81
Hi, thanks hugely for all posts. Great reading and they’ve given me much to think about and investigate.
2 things I don’t understand (amongst many others) are;
a) why we need an increasing amount of energy input when accelerating?, and,
b) Deep space viscosity at at nearly c. I interpret the comments like this:
blue shift will accelerate approaching photons real* energy to such high levels as to obliterate the ship.
If so, would there be a real corresponding depletion of energy density behind the ship?
*I use real in the sense that these effects could interact with the ship
Thanks again
  • #82
Thanks again
a) In SR, as opposed to Newtonian physics, total energy of a particle in a given frame of reference is $$E = \gamma mc^2$$ where $$\gamma = \frac 1 {\sqrt{1 - v^2/c^2}}$$ And, if you draw the graph of energy as a function of speed (##v##), then you'll find a vertical asymptote at ##v = c##.
That means that no matter how much kinetic energy you add to the particle, it never reaches a speed of ##c## relative to the original (or any) reference frame.
b) The CMB radiation is a major practical problem to relativistic space travel, as the energy of the CMB relative to the spaceship increases without limit (in the same way that the energy of the spaceship increases without limit in the original reference frame). As the ship gets faster relative to the original frame, so the CMB photons in front of the ship get more and more energetic, through UV to X-rays and eventually to gamma rays.
And, yes, the CMB coming from behind the ship will redshift to lower and lower energies relative to the ship.
  • #83
Because you have to overcome an increasing force pushing back against the ship. Just considering the CMB alone (and, as has been mentioned, the CMB is not the only thing that can cause a force pushing back against the ship--the interstellar medium contains other things as well), the possible sources of a force pushing back against the ship, which include radiation pressure, inverse Compton scattering, and pair production (just to name those that have been mentioned in this thread), all increase in magnitude as the ship's velocity relative to the CMB rest frame increases. (The relative magnitudes of these effects also change as the ship's velocity increases--much of the discussion in this thread has been focused on how high a gamma factor you have to achieve for pair production to become significant.) So as the ship's velocity increases, the force pushing back on it due to the CMB also increases, which means the ship's engines would have to burn more energy and produce more thrust to keep it accelerating at the same proper acceleration.
  • #84
thank you :)
  • · Replies 22 ·
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 25 ·
  • · Replies 33 ·
