Need explanation on Chracteristic Length in heat convection
The discussion focuses on determining the appropriate characteristic length for calculating the Grashof number in a thermal circuit involving natural convection from a hollow isothermal cylinder, specifically a DVD-shaped hot plate. The characteristic length should be chosen based on the heat source's location; if the heat source is internal, the inner diameter (ID) is preferred, while for external sources, the outer diameter (OD) or the length of the cylinder may be used. The governing equations of mass, momentum, and energy should be utilized to nondimensionalize and confirm the correct length scale for accurate convection coefficient calculations.
  • Understanding of Grashof number calculations
  • Knowledge of natural convection principles
  • Familiarity with governing equations in fluid dynamics (Navier-Stokes equations)
  • Concept of characteristic length in heat transfer
  • Research the calculation methods for Grashof number in natural convection scenarios
  • Study the Navier-Stokes equations with a focus on temperature effects
  • Explore the impact of characteristic length on convection coefficients
  • Investigate thermal circuit design principles for cylindrical geometries
Thermal engineers, mechanical engineers, and researchers involved in heat transfer analysis and thermal circuit design will benefit from this discussion.
thiru muruga
Hi,
I am working on constructing a thermal circuit where I am using the concept of natural convection from a vertical hot plate in the shape of a DVD. In order to calculate the Grashoff number, I have to use the characteristic length. What should I take as my characteristic length? The disc OD or ID or average of OD and ID?
Could you also explain the concept behind characteristic length?
Can you upload a sketch of the problem?
The cylinder is hollow and isothermal. I need to calculate convection coefficient for the heat transfer taking place from the two ends of the cylinder to ambient when the cylinder is placed horizontally. I assume that the ends are similar to circular disc (like a DVD) and need to calculate the Grashoff no. for which I need to know what is the characteristic length.
What/where is the heat source? For charictaristic length I would use the largest length scale of the fluid, which would correspond to the largest vortex in the flow. If the heat source was inside the cylinder, for example, then it would be best to use the ID. If it was from outside, then I'd say either the OD or length depending on the direction of the flow. You can always write down the governing equations (mass, momentum, energy) and nondimensionalize yourself to determine the proper length.
See the energy equation of Navier Stokes using temperature, not enthalpy
The cylinder itself is the source, cause I m trying to model a copper winding here which is cylinderical. The source is heat generated due to copper loss.
  • · Replies 34 ·
