Need help calculating wavelengths of L(alpha) and L(beta
  • Thread starter Thread starter obi-wan
    Wavelengths
The discussion revolves around calculating the wavelengths of L(alpha) and L(beta) x-ray photons from a copper target (Z=29). The original poster uses the formula E=hc/lambda to find the wavelength but is uncertain about their approach, particularly regarding the nature of alpha and beta rays. Participants clarify that these terms likely refer to electron transitions in copper, specifically Lyman-alpha and Lyman-beta transitions, but note the complexity due to copper's multiple electrons. There is confusion about whether to treat copper as hydrogen-like or consider electron screening effects, leading to the suggestion to seek clarification from a tutor. The thread emphasizes the need for a clearer understanding of the question to proceed effectively.
obi-wan
Hi, I need some guidance on a particular question for my coursework.
The questions states: Calculate the wavelength of L(alpha) and L(beta) x-ray photons produced from a copper target (Z=29)
I have tried finding the wavelength using E=hc/lambda and re-arranged for lambda (lambda=hc/E)
Is this the correct approach to solving the problem? Alpha and beta rays travel at the same speed ~ 3*10^8m/s, seems like I'm missing something.
I don't want answers as this doesn't help me in any way but just need some guidance as to how it can be worked out.
Your help is much appreciated..
Alpha and beta rays no not travel at the same speed, they aren't photons. They are likely talking about specific electron transitions in copper. I'm guessing they are talking about Lyman-alpha and Lyman-beta. Look those up and see if it looks like that's what L(alpha) and L(beta) mean.
I also certain they are talking about Lyman alpha and beta transitions, like Dick suggested. The only problem is that copper has obviously many electrons.
So maybe they are referring to transitions of the last electron (the first 28 electrons fill the n=1,2 and 3 shells). So maybe they are referring to the transition between n=4 and n=5? I am not sure what they would use for the charge of the screened nucleus. The most simple-minded thing to try is Z=1 but in real life the outer electron would see a screened value a bit different than this.
On the other hand, Lyman usually refers to transitions from n=1 so would they assume a hydrogen-like copper atom? (one for which 28 electrons have been stripped off?) In which case one would use the Bohr energy level equation with Z=29. But this interpretation seems unlikely.
When x-rays strike an electron on a copper surface this produces a radiation and a recoiling electron. However this radiation is not in the form of gamma or beta rays (correct me if I'm wrong here)
The question seems to be missing something and I can't think of anything else that would relate the gamma and beta rays to x-ray photons. The question does not talk about transitions between any energy levels.. best to ask my tutor to see if he makes sense of it.
thanks for your time Dick & nrqed.
I don't understand the question then. The question askes about X ray photons produced by Cu atoms. Here you are talking about bombarding Cu atoms with x-rays. I did not think that was the question. But I am maybe completely misinterpreting.
Better clarify things with your tutor.
best luck!
sorry I've confused you there :) yes the question does ask about x-ray photons being produced by a Cu target. Nevermind, I will see my tutor tomorrow and get him to clarify things. Will keep this thread updated once the question makes sense, hopefully solving it and marking the thread as 'Solved'
thank you nrqed
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
