How Do You Evaluate the Limit of (1/tan(x) - 1/x)/x Using Taylor Series?
  • Thread starter Thread starter lep11
    Limit
The discussion focuses on evaluating the limit of (1/tan(x) - 1/x)/x as x approaches 0 using Taylor series. Participants suggest substituting tan(x) with its Taylor expansion, leading to a series of calculations that reveal a common error in the signs and coefficients used in the expansion. The correct limit is determined to be -1/3, with some contributors recommending the use of L'Hôpital's rule as a simpler alternative. The conversation emphasizes the importance of correctly applying Taylor series and checking for accuracy in the expansions used. Ultimately, the limit evaluation showcases the interplay between different mathematical techniques.
lep11
Evaluate the limit ##\lim_{x\to0} \frac{1}{x}(\frac{1}{tanx}-\frac{1}{x}) ## using Taylor's formula. (Hint: ##\frac{1}{1+c}=\frac{1-c^2+c^2}{1+c} ## may be useful)
I began by substituting ##tanx## with ##x+\frac{x^3}{3}+x^3ε(x)##, where ε tends to zero as x approaches 0.
##\frac{1}{x}(\frac{1}{tanx}-\frac{1}{x})=\frac{1}{x}(\frac{x-tanx}{xtanx})=\frac{1}{x}(\frac{x-x-\frac{x^3}{3}-x^3ε(x))}{x(x+\frac{x^3}{3}+x^3ε(x))})=\frac{1}{x}(\frac{-\frac{x^3}{3}-x^3ε(x))}{x(x+\frac{x^3}{3}+x^3ε(x))})=\frac{-\frac{x^3}{3}-x^3ε(x))}{x^2(x+\frac{x^3}{3}+x^3ε(x))}=\frac{-\frac{x^3}{3}-x^3ε(x))}{x^3+\frac{x^4}{3}+x^4ε(x))}=\frac{-\frac{1}{3}-ε(x))}{1+\frac{x}{3}+xε(x))}## →-1/3 as x→0
substituting ##tanx## with ##x-\frac{x^3}{3}+x^3ε(x)##, where ε tends to zero as x approaches 0.
##\frac{1}{x}(\frac{1}{tanx}-\frac{1}{x})=\frac{1}{x}(\frac{x-tanx}{xtanx})=\frac{1}{x}(\frac{x-x-\frac{x^3}{3}+x^3ε(x))}{x(x-\frac{x^3}{3}+x^3ε(x))})=\frac{1}{x}(\frac{\frac{x^3}{3}+x^3ε(x))}{x(x-\frac{x^3}{3}+x^3ε(x))})##
You're not far from the answer. After cancellations, you have: \frac{\frac{x^3}{3} + ...}{x^3 + ...}, where ... represents higher-order terms. If you ignore the higher-order terms, what do you get?
It's 1/3. But where to use the hint I am given?
You lost a minus sign in the numerator.
I don't get that, either.
You are right. It's a typo.
I began by substituting ##tanx## with ##x-\frac{x^3}{3}+x^3ε(x)##, where ε tends to zero as x approaches 0.
##\frac{1}{x}(\frac{1}{tanx}-\frac{1}{x})=\frac{1}{x}(\frac{x-tanx}{xtanx})=\frac{1}{x}(\frac{x-x-\frac{x^3}{3}+x^3ε(x))}{x(x-\frac{x^3}{3}+x^3ε(x))})=\frac{1}{x}(\frac{\frac{x^3}{3}+x^3ε(x))}{x(x-\frac{x^3}{3}+x^3ε(x))})=\frac{\frac{x^3}{3}+x^3ε(x))}{x^2(x-\frac{x^3}{3}+x^3ε(x))}=\frac{\frac{x^3}{3}+x^3ε(x))}{x^3-\frac{x^4}{3}+x^4ε(x))}##??
I think you've got the wrong series for ##tan(x)##. Check your coefficients. Also, if you are going to use the Taylor series, you should use the series for ##1/tan(x)## by applying the binomial expansion to the series for ##tan(x)## or using the series for ##cot(x)##.
That said, this one looks tailor-made(!) for L'Hopital, using ##tan = sin/cos##.
No, I think he started with the wrong expansion for tan(x). It should be tan(x) = x + \frac{x^3}{3} + ... not x - \frac{x^3}{3}
Yes, he has a wrong Taylor series. In the denominator, that should have been ##+\frac{x^3}{3}##. But in the numerator, he expands ##x-\tan x##, so the ##\frac{x^3}{3}## gets a minus sign.
When taking the limit, the ##x³## term resulting from the ##\tan## series in the denominator is not important, but the one in the numerator is.
The correct limit is ##-\frac13##.
My advice would be to do it the easy way using L'Hopital so you know what the answer is, then do it the hard way using Taylor series :wink:
Sure, the hints he got are strange. This is, as you said, tailor-made(!) for L'Hopital.
##\frac{1}{x}(\frac{1}{tanx}-\frac{1}{x})=\frac{1}{x}(\frac{x-tanx}{xtanx})=\frac{1}{x}(\frac{x-x-\frac{x^3}{3}-x^3ε(x))}{x(x+\frac{x^3}{3}+x^3ε(x))})=...=\frac{-\frac{x^3}{3}-x^3ε(x))}{x^3+\frac{x^4}{3}+x^4ε(x))}=\frac{-\frac{1}{3}-ε(x))}{1+\frac{x}{3}+xε(x))}## →-1/3 as x→0
Looks like I didn't need the hint. However, I think I'm supposed to derive the Taylor formula I used for the problem. We have covered expansions for sinx and cos x in class. So ##tanx=\frac{sinx}{cosx}=\frac{x-\frac{x^3}{3!}+\frac{x^5}{5!}-...}{1-\frac{x^2}{2!}+\frac{x^4}{4!}-...}=##
I would go for: ##1/tanx = cosx/sinx##
You might as well make things easy for yourself!
Use the binomial for ##1/sinx = (x-\frac{x^3}{3!}+\frac{x^5}{5!}- \dots)^{-1} = (1/x)(1-\frac{x^2}{3!}+\frac{x^4}{5!}- \dots)^{-1}##
I actually derived the expansion for ##\tan x## from the definition of taylor formula. ##f'(x)=D\tan x=1+\tan^2 x##, ##f'(0)=1##
##f''(x)=2\tan x(1+\tan^2 x)##, ##f''(0)=0## etc. and got ##\tan x=x+\frac{x^3}{3}+x^3ε(x)##. I think this is maybe shorter and nicer than deriving it by long division.
PeroK said:
I would go for: ##1/ \tan x = \cos x / \sin x##
I thought I had posted something on this a day or two ago. Using the first of Perok's suggestions, then common denominator, etc. :
##\displaystyle \
\frac{1}{x}\left(\frac{1}{\tan x}-\frac{1}{x}\right)
##\displaystyle \
=\frac{x \cos x - \sin x}{x^2\sin x}
Now use the Taylor expansions for sin x and cos x .
  • · Replies 22 ·
