Need help from someone who knows about importance sampling.
  • Thread starter af_231
  • Tags
    Sampling
In summary, we discussed the concept of importance sampling and how it can be used to divide a probability distribution into two parts for the purpose of applying stratified sampling. We also touched upon the idea of using a probability distribution function to determine which areas of a function should be oversampled or undersampled. Lastly, we clarified terminology and discussed the basic function of sampling methods.
af_231
Hello!
My question is about Importance Sampling. I am trying to apply a complex sampling method, which combine two sampling techniques. To do this, the importance sampling is used ONLY to divide the probability distribution into two main parts: Part 1: from 0 to p*, and Part 2: from p* to 1. Then, the method continues with the application of stratified sampling.
I would appreciate if someone can help me or explain me Importance Sampling... how to use this technique only to divide the probability? How to know which is the p* value, where the distribution should be divided?
I really appreciate your help...Any information will helpful.
I found in internet the following text:
"Importance Sampling attempts to do more samples at the areas of the function that are more
important. The way it does this is by bringing in a probability distribution function (pdf). All this is, is a function that attempts to say which areas of the function in the interval should get more samples. It does this by having a higher probability in that area."
Does this mean that p* is the CDF value that corresponds to the largest PDF value? ... I don't know, I am confused.
Mathematics news on Phys.org
Thanks!... and I'm sorry about my mistake, I am new in statistics area, but I'm trying to learn.
No need to apologize.
A very short answer to your original question. Assume you have a random variable X and you want to estimate the average of f(X) using Monte Carlo. Then you would oversample X where f(X) is high and undersample where f(X) is low and compensate for the biased sapling by weghts (low for oversample and high for undersample). If done properly, the weighted average has a mean equal to the answer you are looking for, while the standard deviation is reduced in comparison to using unbiased samples.
Thanks for your help Mathman!
Can I ask you a favor?... maybe you can help me answering some questions about sampling methods and analysis of risk. I have these doubts and maybe you can help me to answer them.
Question 1) Is this correct?: The basic function of the sampling methods is to generate random numbers with similar characteristics or properties to the original sample. I mean, applying a sampling method, the output is a random sample?
Question 2) My original data is a time series data from which I selected the best fitted distribution through frequency analysis. As part of a risk analysis, I must apply a sampling method... my question is, the random numbers generated by this sampling method should be generated according to the best fitted distribution chosen on the frequency analysis?
Thanks! I really appreciate your help!
We need to clarify terminology. You are using the term "random number" in a non-standard fashion. I find it hard to understand what you are trying to do.
1. What is importance sampling?
Importance sampling is a technique used in statistics and probability to estimate properties of a particular distribution by selecting samples from a different distribution that is easier to sample from.
2. When is importance sampling used?
Importance sampling is commonly used in situations where the target distribution is difficult to sample from directly, but a related distribution is easier to sample from. It is also used to improve the accuracy of Monte Carlo simulations and to estimate rare events.
3. How does importance sampling work?
Importance sampling works by generating samples from a different distribution, called the proposal distribution, and then weighting them according to the ratio of the target distribution to the proposal distribution. This allows us to estimate properties of the target distribution based on the samples from the proposal distribution.
4. What are the benefits of using importance sampling?
Importance sampling can greatly improve the efficiency of Monte Carlo simulations, especially when the target distribution is complex or has rare events. It also allows us to estimate properties of the target distribution without having to sample directly from it.
5. What are some common pitfalls when using importance sampling?
One common pitfall is choosing a proposal distribution that is too different from the target distribution, which can lead to high variance and inaccurate estimates. It is also important to properly normalize the importance weights to avoid biased estimates. Additionally, it may be challenging to find a suitable proposal distribution for complex target distributions.
  • Set Theory, Logic, Probability, Statistics
  • General Math
