MHB Need Help Solving a Physics Problem? T=____?
  • Thread starter Thread starter cake81
    Physics
To solve the physics problem, the initial height of the tennis ball is 2 meters, with an initial upward velocity of 9 m/s and a downward acceleration of 10 m/s². The kinematic equation used is y = y₀ + v₀t + 0.5at², leading to the equation 5t² - 9t - 2 = 0. The solution yields two values for T, but only the positive value is relevant for the time until the ball hits the ground. The final answer for T is confirmed to be 2 seconds.
cake81
Hello! I need help with this question:
A tennis ball is thrown in the air by a man so that at the instant when the ball leaves his hand, the ball is 2m above the ground and is moving vertically upwards with speed9m/s^-1
The motion of the ball is modlledas that of a particle moving freely under gravityand the acceleration due to gravity is modeled as being of constant magnitude of 10 m/s^-1
The ball hits theground T seconds after leaving the hand
Using the model, find the value of T
I don't know how togo about solving this because I don't understand the part with the particle moving freely
Mathematics news on Phys.org
Welcome, cake81! (Wave)
We are given an initial height of $y_0 = 2\,\text{m}$, an initial velocity of $v_0 = 9\, \text{m/s}$ in the upwards vertical direction, and an acceleration of $a = -10\,\text{m/s}$ (the acceleration vector faces downwards). Using the kinematic equation
$$y = y_0 + v_0 t + .5 at^2$$ with $y = 0$ we solve $0 = 2 + 9t + (.5)(10)t^2$, or $$5t^2 - 9t - 2 = 0$$ Can you take it from here?
thank you so much. i got 2, i only have to use the positive answer right?
Yes. Only the positive answer makes sense.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
