Need help understanding Lagrange multipliers at a more fundamental level.
The discussion revolves around understanding Lagrange multipliers, focusing on their fundamental principles, applications in finding extreme values of functions under constraints, and the reasoning behind their effectiveness. Participants explore theoretical and conceptual aspects, as well as practical examples involving functions of two or three variables.
  • Homework-related
  • One participant questions how to determine whether a critical point is a maximum, minimum, or saddle point, especially when only one extreme value is available.
  • Another participant suggests comparing values of points close to the critical point as a method for determining the nature of the critical point.
  • Participants discuss the reasoning behind Lagrange multipliers, explaining that the gradient of a function points in the direction of the fastest increase, and that constraints require projecting this gradient onto the tangent surface defined by the constraint.
  • There is mention of the relationship between the gradients of the function and the constraint, where they are said to be parallel when the maximum or minimum occurs.
  • One participant raises a question about the broader significance of Lagrange multipliers, linking them to concepts in partial differential equations and Green's functions.
  • A later reply seeks clarification on whether the maximum and minimum found are based on the constraint rather than the function alone.
Participants express varying levels of understanding and inquiry about the topic, with some questions remaining unanswered. The discussion does not reach a consensus on all points, particularly regarding the broader implications and interpretations of the method.
Participants express uncertainty about the nature of critical points and the implications of constraints on the maxima and minima of functions. There are also unresolved questions about the significance of Lagrange multipliers in other areas of mathematics.
smize
I understand that for Lagrange multipliers,
[itex]∇f = λ∇g[/itex]
And that you can use this to solve for extreme values.
I have a set of questions because I don't understand these on a basic level.
1. How do you determine whether it is a max, min, or saddle point, especially when you only get one extreme value/critical point.
2. Why does this work? Could someone help paint a picture or better description of why you can find these critical points using Lagrange multipliers?
3. Is there a more significant purpose for Lagrange multipliers?
You may use any problem where you have either [itex]f(x,y)[/itex] with the constraint [itex]g(x,y) = k[/itex] or with [itex]f(x,y,z)[/itex] with the constraint [itex]g(x,y,z) = k[/itex]
Both would be preferred; The former preferred for a basic understanding, the latter for a more complex example.
Any help would be appreciated, I have a quiz and test over it this week.
By comparing values of points close by the critical point.
Suppose you want to maximize some function f(x,y,z) without any constraint. The "gradient" of f, [itex]\nabla f[/itex] is a vector pointing in the direction of fastest increase. So, starting at any given point, calculate [itex]\nabla f[/itex] at that point, and move in its direction. Keep doing that until you can no longer do it. The only reason you could "no longer do it" is because the gradient vector does not have a 'direction'- and that would be when [itex]\nabla f= 0[/itex].
Now, suppose we have the constraint g(x,y,z)= constant, so we are constrained to stay on some surface satisfying that equation. We can still caculate [itex]\nabla f[/itex], but if it does not happen to be tangent to the surface, we can not "move in its direction". What we can do is find its projectin tangent to the surface and move in that direction. We can continue doing that until there is no projection of [itex]\nabla f[/itex] tangent to the surface. That will happen if and only if [itex]\nabla f[/itex] is itself normal to the surface. But, of course, for any surface g(x,y,z)= constant, [itex]\nabla g[/itex] is perpendicular to the surface so we are saying that [itex]\nabla f[/itex] and [itex]\nabla g[/itex] are both perpendicular to the surface- they are parallel and so one is a multiple of the other: [itex]\nabla f= \lambda\nabla g[/itex] for some constant, [itex]\lambda[/itex].
Not sure what you mean by this but in the theory of partial differential equations, "Green's functions" can be derived in a manner similar to lagrange multipliers.
So, is the max and min found a max and min based on the constraint, and not a regular max/min of [itex]f(x,y)[/itex] or [itex]f(x,y,z)[/itex]?
Nevermind. I understand now. I spent 2 seconds on the wikipedia page for it, and I finally had that "Oh my God. I get it." moment.
