Need help with a centripetal force question
The discussion revolves around solving a centripetal force problem involving a hanging mass and a puck. The user correctly applies the formula for centripetal force, concluding that the speed of the puck is approximately 8.57 m/s. However, they question the discrepancy between their answer and the professor's solution of 10.5 m/s. Other participants confirm the user's calculations are logical but suggest that rounding and significant figures may account for the difference. The conversation emphasizes the importance of precision in reporting final answers in physics problems.
sens
[/B]
[/B]
mv^2 / r = F
This is my attempt and reasoning for this problem, is this the correct way to approach the problem or am i missing something?the hanging mass is motionless the tension in string equals the force of gravity on mass m2, therefore
T = 4*9.8N
The horizontal force on the puck (which is the centripetal force) is the same as the tension.
F(horizontal) = 4*9.8 N
(c) mv^2 / r = F(centripetal) ===> (0.8)(v^2) / (1.5) = 4*9.8 ===> v = 8.57321 m/s
Your logic and method look good. You'll want to display the end result with the correct number of significant figures though.
Are you sure the answer is correct? The solution key that the professor just posted said the answer was 10.5 m/s so I'm trying to figure out where i went wrong.
I don't see any problem with your solution. Your result is correct for the problem given.
You might make your answer 10 m/s if you were rounding to one significant digit, but your professor's result has three. So that won't account for the difference.
ok thank you for your help
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
