Need help with Poisson's equation for a charged cylinder
  • Thread starter Thread starter snatchingthepi
    Charged Cylinder
The discussion centers on solving Poisson's equation for an infinite cylinder with uniform charge density. The user successfully applied Gauss' law to derive the electric potential equations for both inside and outside the cylinder. The potential equations are given as V = (-λ / 2πε) ln(b/a) for outside and V = (a² - b²)(λ / 4πεR²) for inside. The user seeks assistance in determining the constants C₀ and C₁ in the derived potential equation V = - (λr² / 4ε) + C₀ ln(r) + C₁.
  • Understanding of Gauss' law in electrostatics
  • Familiarity with Poisson's equation and its applications
  • Knowledge of electric potential and charge density concepts
  • Basic calculus for integration and solving differential equations
  • Research methods for determining constants in potential equations
  • Study the application of Poisson's equation in cylindrical coordinates
  • Learn about boundary conditions in electrostatics problems
  • Explore the implications of symmetry in electric fields and potentials
This discussion is beneficial for physics students, particularly those studying electromagnetism, as well as educators and professionals seeking to deepen their understanding of electrostatic potentials in cylindrical geometries.
snatchingthepi
Compute the scalar potential and the electric field for an infinite charged cylinder. Assume the length density q/L is constant. Solve using Gauss' law and Poisson's equation
##\int \vec E \cdot d\vec a \ = \left(\frac Q \epsilon \right)##
##\nabla^2 V = \left(\frac \rho \epsilon \right)##
So I'm trying to solve for the field and potential inside and outside of an infinite cylinder with uniform charge to length density.
Using Gauss' law I am able to do this very easily and get the answers.
## V = \left(\frac {-\lambda} {2\pi\epsilon} \right) \ln\left(\frac b a \right)## for outside
## V = (a^2 - b^2) \left(\frac \lambda {4\pi\epsilon R^2} \right) ## for inside
where 'a' and 'b' are just points used to perform the integration.
And now I got to do it with Poisson's equations, and working back through the equation, and realizing that I have symmetry to help me out here, I end up with the results that
## V = - \left(\frac {\lambda r^2} {4\epsilon}\right) + C_0 \ln r + C_1 ##
where 'r' is the distance from the axis of the cylinder. I don't really know where to go next with this. I realize I have to find these two constants, but I don't really know how. I searched the forum and found this post (https://www.physicsforums.com/threa...of-a-cylinder-using-poissons-equation.598097/) but I haven't gotten much out of it.
I have been ill for the past week and haven't been able to do any work, but this assignment is due tomorrow afternoon and I feel very time-pressured. I'd appreciate any help with this.
Is this a solid cylinder, or a shell? a and b must be geometries, not just "..used to perform the integration..."?
Restate the problem accurately & we may be able to provide assistance.
Rudeman all the information is present in the problem statement, and the use of arbitrary points to determine a potential difference is acceptable with infinite cylinders since the potential does not behave at zero or infinity.
I understand about a and b, yes, potential must be between two finite points.
But - is b "outside" and a can be either "outside" or "inside"? Or vice-versa? Or, are both a and b either "outsie" or "inside"? I'm guessing the last.
And I a ssume the cylinder is solid.
The problem is ill-stated. You should be able to answer these questions or ask the poser to.
I feel as though you are completely neglecting the actual purpose of this post. Regardless of how you feel my problem is stated, you are pedantically distracting attention away from the actual question.
But yes, you are right in your assumptions.
  • · Replies 16 ·
