Calculating Pressure Difference in a Vertical Water Pipe
  • Thread starter Thread starter jrzygrl
The discussion centers on calculating the pressure difference in a vertical water pipe extending 420 meters. The initial calculation incorrectly used a water density of 1 kg/m³ instead of the correct value of 1000 kg/m³. This error led to an incorrect pressure difference of 0.0407 atm. Upon correcting the density, the accurate pressure difference can be recalculated. The importance of using the correct density in fluid mechanics calculations is emphasized.
jrzygrl
A vertical water pipe extends from the bottom to the top of the World Trade Center in the Big Apple (New York City), a distance of about 420 m. Calculate the difference in pressure in atm between the bottom and the top of the water pipe.
p(y) = p - \rhogy
\rhogy = (1 kg/m^{3}) (9.81m/s^{2}) (420m)
\rhogy = 4120.2 Pa
4120.2 Pa (1 atm / 101300 Pa) = .0407 atm
The answer above was wrong. Thanks for the help!
The density of water isn't 1kg/m^3. It's 1000kg/m^3!
ohhh, that's what was wrong. thanks a lot! :smile:
  • · Replies 23 ·
  • · Replies 16 ·
