Negative Values of the Frictional Force?
The discussion revolves around a physics problem involving the calculation of the coefficient of kinetic friction for a block that accelerates to a velocity of 40 m/s over a distance of 100 m, starting from rest. The problem includes forces such as weight and applied force, and participants are exploring the implications of a negative coefficient of friction derived from their calculations.
  • Participants discuss the equations used to analyze the forces acting on the block, questioning the inclusion of terms like inertia and the horizontal component of weight. There are attempts to clarify the direction of forces and their contributions to the net force, as well as concerns about the physical validity of a negative coefficient of friction.
The conversation is ongoing, with participants providing insights and questioning each other's reasoning. Some have suggested re-evaluating the problem setup and the values given, while others have pointed out potential errors in the equations used. There is no explicit consensus, but several participants are collaboratively exploring the inconsistencies in their calculations.
Participants note the possibility of incorrect data being used in the problem, as well as the challenge of applying concepts typically used for inclined planes to a horizontal scenario. The discussion highlights the complexity of force interactions in this context.
AilingLore21
6110bc6d-047f-4ce3-8462-1248e3134b33.jpe
Ignore B & C for now
The block in the figure reaches a velocity of 40 m/sec in 100 m, starting from rest. Compute the coefficient of kinetic friction between the block and the ground.
W = 100N
F = 40 N
2. Homework Equations
∑Fy = 0 so Normal Force = Weight
∑Fx = Force - Inertia - Frictional Force - Weight = 0
0.5 (V^2 -Vo^2) = as
0.5 (40^2 - 0) = a(100m)
a = 8 m/s^2
So I got this equation:
40 N = 100 N ( cos90) + 100N (8m/s^2 / 9.806 ) + 100 N ( μ)
I ended up getting a negative coefficient of friction which is
-0.415827. Is there something wrong with my equation?
You cannot have a negative coefficient of friction.
Also, write out your equation in variable form.
Think about the directions of the forces, how they add or subtract.
0.5 (V2 -Vo2) = 2 * a * d
∑Fy = 0
W = 100N
N - W = 0
so W =100 N∑Fx = 0
F = 40 N
F - Ff - W ( a / g ) - W = 0
The inertia naturally resists the motion so it's negative, frictional force too. Weight is multiplied by the cosine of 90 so it's technically zero. Force appears to be going to the right so it's positive. I'm still having trouble why it's a negative value when computed
If Ff is the frictional force, what is W?
Weight, so are you saying Weight does not exist on a horizontal movement ?
But the acceleration must have the same direction and the same sign as the net force.
It has no effect that isn't already accounted for: weight by definition acts only vertically, and in this case is balanced by the normal force. You have the coresponding mass in the term that includes g.
I see a couple of problems with this equation.
1. You say that the net force (sum of all the forces) is zero. That is true only if the acceleration is zero. This is not true here because the block starts from zero velocity and reaches 40 m/s some time later. Therefore the acceleration cannot possibly be zero.
2. You show 4 forces acting in the horizontal direction. I can only see 2 that make sense, "Force" (pushing the block) and "Frictional force" (from the ground contact). Where does "Inertia" come from? What about "Weight"? Is that in the horizontal direction?
I got the same answer. Maybe we are both crazy.
Ok , so this gave me an idea
∑Fx = 0
F = 40 N
F - Ff + W ( a / g ) = 0
So if I compute again
40 - Ff + 100 ( 8m/s2 / 9.806)
I would get a Ff of 121.5827 N
divide that by 100 and I get a coefficient of 1.22
Seems pretty large for a coefficient of friction
AilingLore21 said:
∑Fx = 0
This is wrong.
Read what @kuruman said.
If a force of 40 N is applied to a mass of 10 kg, you get an acceleration of 4 m/s^2. So how can you get an acceleration of 8 m/s^2 unless you have another force acting in the same direction. Thus, a negative μ.
Maybe it's too earl for me and I'm not fully awake yet.
Edit: See ^. I can't even type "early".
Interestingly enough, I also got that same negative answer. I'm not sure what could've gone wrong here unless the data from the original question was copied down incorrectly, since a negative coefficient of friction is physically impossible.
Either written down wrong, or a poorly-thought-out problem.
Yeah both are very possible
@AilingLore21 Can you check if all of the values in the problem are written down correctly.
I think you have the wrong sign for the acceleration; but I agree something is strange here. The block was accelerated at almost g, which as far as I can see is incompatible with a 40 N force and a 100/g kg mass. Have you checked the given data, including units?
I somewhat figured out that
They are apparently. I'm used to solving the inclined versions of these. I wonder why I'm having this much trouble on a horizontal one
Actually, your first answer of μ = -0.416 looks like it was correct. But I could not understand your method. It seemed like there were some problems.
For example, if you could explain how this equation came about.
Look, if the contact were frictionless, the acceleration would be
$$a=\frac{F}{W/g}=\frac{40}{100/9.8} = 3.92~m/s^2$$
How can the acceleration with friction be about twice a much? If the numbers are copied correctly, they are not thought out correctly.
Actually, the more I look at your equation, the more it makes sense. The only thing that is really questionable in that equation is the 100cos90 term. Where did that come from?
One other tip: It is best to leave out units in these equations. Just include them in the final result.
If I throw out the 100cos90 term in your equation, I am left with:
40 = (100)(8/9.8) + 100μ, which is derived from:
ΣF = ma
F - f = ma (where F is the 40 N applied force and f is the friction force)
40 - μ(100) = (100/9.8)(8)
Solving gives μ = -0.416.
So I think you were pretty much on the right track, except for that 100cos90 term.
You can safely do that, ##\cos 90^o =0##.
kuruman said:
You can safely do that, cos90=0.
For sure. I just think it shows a lack of understanding that it was there in the first place.
I don't know if you'd find it helpful, but I like to start from Newton's law for this type of problem.
Net Force = Mass x Acceleration.
You've found the acceleration. The mass is 100/g kg.
The net force is the applied force less the frictional force = 40 - 100.μ N (where μ is the frictional coefficient to be found).
I get the same negative answer you did originally, too.
Perhaps. Although not as simple as zero, 100 N cos90o is, nevertheless, the horizontal component of the weight.
Usually as folks progress on in the study of physics, they learn that they can usually omit the horizontal component of weight. :)
Actually, the more I think about it, the more I think I agree with you - that it might not show a lack of understanding. It could actually be an indication of a fairly thorough understanding of the fundamental concept.
Indeed, but I think this is not a good problem for honing one's physical understanding as I indicated in post #22.
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 37 ·
  • · Replies 23 ·
