Nested for loop in python, understanding with dry run?
  • Topic: Python
  • Thread starter Thread starter shivajikobardan
    Loop Python
shivajikobardan
Here is the code that I am talking about-:
Code:
n=int(input("Enter a number"))
for num in range(2,n+1):
    for i in range(2,num):
        if(num%i==0):
            break
    else:
        print(num,end="")
If I give n=5 output should be 2,3,5.
Here is my dry run. Everything is fine except for 2 where I am not getting 2 as output. What has gone wrong here? I don't understand what is gone wrong here?
PeroK said:
You need ##num +1## in the second range.
I don't think the question is "what is wrong with my program", but it is "what went wrong with the dry run (see picture)". The program runs fine and outputs 2,3 and 5.
The dry run went wrong because the range for num =2 is (2,2). This is an empty range. A for loop for an empty range doesn't run the first part at all, and will immediately go to the else: (or skip the entire thing if there is no else:).
If there was num+1 in the second range, the range would be (2,3), the 2%2 would be tried and there would be the wrong conclusion that 2 is not prime.
I would also eliminate the nested for loop by moving the inner loop in a function
Python:
def isprime(num):
    for divisor in range (2,num):
        if (num % divisor) == 0:
            return False
    return True
    if isprime(num):
        print(num,end=" ")
I don't really like nested loops, unless it's something like rows and columns.
@shivajikobardan here's my basic python script to find prime numbers:
Python:
# Find, count and print all primes up to max_num
primes = [2, 3, 5, 7, 11, 13, 17, 19]
max_num = 1000
prime_flag = False
for n in range(23, max_num+1, 2):
    sqrt_n = n**0.5
    for p in primes:
        if n % p == 0:
#            print(f"{n} is not prime")
            prime_flag = False
            break
# Only search for primes less than or equal to the square root of n
        if p > sqrt_n:
#            print(f"{n} is prime")
            prime_flag = True
            break
    if prime_flag:
        primes.append(n)
print(primes)
print(len(primes))
