How Do You Calculate the Angle of the Net Magnetic Force in a Complex Field?
The discussion focuses on calculating the angle of the net magnetic force acting on a charged particle in a magnetic field with components of 0.074 T along the +x axis and 0.020 T along the -y axis. The net magnetic force magnitude was determined to be 0.018397 N using the formula F = Bqv sin(90°). The participant initially struggled with finding the angle of the net force but resolved the issue by switching the Y and X directions, emphasizing the importance of vector analysis over scalar methods in magnetic field problems.
  • Understanding of magnetic force calculations using F = Bqv sin(θ)
  • Familiarity with vector analysis and components in three-dimensional space
  • Knowledge of the right-hand rule for determining force direction
  • Experience with the determinant cross product method for vector calculations
  • Study the determinant cross product method for vector calculations in physics
  • Learn about vector components in three-dimensional magnetic fields
  • Explore advanced applications of the right-hand rule in electromagnetism
  • Investigate the implications of magnetic field strength and direction on charged particles
Physics students, educators, and professionals working with electromagnetism, particularly those dealing with charged particles in complex magnetic fields.
Crimsonangel
One component of a magnetic field has a magnitude of 0.074 T and points along the +x axis, while the other component has a magnitude of 0.020 T and points along the -y axis. A particle carrying a charge of +7.50 10-5 C is moving along the +z axis at a speed of 3.20 103 m/s.
(a) What is the magnitude of the net magnetic force that acts on the particle?
(b) What is the angle that the net force makes with respect to the +x axis?
I figured out the first question using F=Bqvsin90 for X anf Y and then used pythag. to get the answer which was 0.018397 N.
I am having problems with (b). I don't know how to find the angle because it is not on a plane I think. The net force has XYZ components and I don't know how to find an angle for that. Could you please help? Thanks!
In order to keep everything straight, I would advise that you think of this problem in terms of vectors, and not in terms of scalars.
That is, chug through the determinant cross product method to get the net force as a vector, and then use vector analysis to find the angle.
If you are used to thinking of magnetic field problems in terms of scalars, now is a good time to learn this new method.
I don't understand what you mean by "determinant cross product method". I thought that to figure out the direction of the force you use the right hand rule. I figured out the force using F=BqvSin90 and figured out the direction of each force using the right hand rule. I then added the vectors. The direction of the force is on the YX plane.
But I just figured it out. I switched the Y and X directions. Thanks for your help though, I appreciate it!
  • · Replies 31 ·
