Neural Network training BUT testing fails
1 reply · 2K views
Hi, I was trying to work on a basic NN training problem I found online. The pattern of data to train are the triplets:
[101]->1 , [011]->1, [001]->0 , [111]->0 , [100]->1
Meaning that the 3rd number brings no info, while for the first 2 if they are identical it should evaluate to 0 else to 1. The last data is to also let it learn what happens when the 3rd argument is 0.
I train on these data and then I am trying to apply what the NN learned on testing data:
[000], [010], [110]
Unfortunately I get 1 back... I assume that the problem is that it somehow learns that if the 3rd argument is 0, it should evaluate to 1 by the last training data point. When I changed the last ->1 to ->0, the tested data also evaluated to 0.
So I migrate one more data point in the training, [110]->0.
and test on: [000] , [010] ... In the latter case, both evaluate to 1. I don't understand why it fails so miserably at 000... any idea?
The code is given below (it's the based on the basic NN code given in many online tutorials but written as a class)...
Python:
import numpy as np
import matplotlib.pyplot as plt
class NN:
    def __init__(self, input_data , output_data=None, testing=None ):
        self.input_data = input_data
        self.testing = testing
        if not testing:
            self.output_data = output_data
        # randomly initialize weights
        np.random.seed(1)
        if testing:
            self.weights0 = testing[0]
            self.weights1 = testing[1]
        else:
            self.weights0 = 2*np.random.random([self.input_data.shape[1], self.input_data.shape[0] ]) -1.
            self.weights1 = 2*np.random.random([self.input_data.shape[0], 1])
        self.errros = None
        self.xerros = []
        self.results = {
                        "OutputTrain": None,
                        "Matrix0": None,
                        "Matrix1": None
    def sigmoid(self, x, derivative=False):
        if derivative: return x*(1-x)
        return 1/(1+np.exp(-x))
    def train(self, Nsteps , test= True):
        self.errors = np.zeros( (self.input_data.shape[0], Nsteps) )
        for step in range(Nsteps):
            l0 = self.input_data
            l1 = self.sigmoid( np.dot(l0, self.weights0 ) ) #(4x3) x (3x4) = 4x4 matrix
            l2 = self.sigmoid( np.dot(l1, self.weights1 ) ) #(4x4) x (4x1) = 4x1 matrix (output)
            if not self.testing:
                l2_err = self.output_data - l2
                delta_l2 = l2_err * self.sigmoid( l2 , derivative=True )
                l1_err = delta_l2.dot(self.weights1.T)
                delta_l1 = l1_err * self.sigmoid( l1 , derivative=True )
                for i in range(self.output_data.shape[0]):
                    self.errors[i][step] = l2_err[i]
                self.xerros.append(step)
                self.weights1 += l1.T.dot(delta_l2)
                self.weights0 += l0.T.dot(delta_l1)
        self.results["OutputTrain"]=l2
        self.results["Matrix1"] = self.weights1
        self.results["Matrix0"] = self.weights0    def summary(self):
        print("Training Results : ")
        print("\t Output data (trained) : ")
        print(self.results["OutputTrain"])
        print("\t Matrix 1 : ")
        print(self.results["Matrix0"])
        print("\t Matrix 2 : ")
        print(self.results["Matrix1"])    def plot(self):
        x = np.array(self.xerros)
        cols = {0:'black',1:'r',2:'g',3:'b',4:'m',5:'y'}
            plt.plot(x, np.array(self.errors[i]), cols[i], label="Entry %s"%i)
            legend = plt.legend(loc='upper right', shadow=True, fontsize='x-large', framealpha=0.05)
            axes = plt.gca()
            axes.set_ylim([-2., 2.])
            #legend.get_frame().set_facecolor('#00FFCC')
        plt.title("Error vs Ntrial")
        plt.show()
if __name__=="__main__":
    x = np.array([[0, 0, 1],
                  [0, 1, 1],
                  [1, 0, 0],
                  [1, 1, 0],
                  [1, 0, 1],
                  [1, 1, 1]])
    # output
    y = np.array([[0],
                  [1],
                  [1],
                  [0],
                  [1],
                  [0]])
    NeuralNetwork = NN(x,y)
    NeuralNetwork.train(25000)
    #NeuralNetwork.plot()
    #NeuralNetwork.summary()
    print("Test Data")
    data_test = np.array([[0,0,0],[0,1,0]])#,[1,1,0]])
    #isOne = (data_test.dot(NeuralNetwork.results["Matrix0"])).dot(NeuralNetwork.results["Matrix1"])
    #isOne = data_test.dot(NeuralNetwork.results["Matrix0"])
    #isOne = isOne.dot(NeuralNetwork.results["Matrix1"])
    #print(isOne)
    tester = NN(data_test, testing = [NeuralNetwork.results["Matrix0"], NeuralNetwork.results["Matrix1"]])
    tester.train(25000)
    #tester.summary()
    print(tester.results["OutputTrain"])
Your training dataset is compatible with the hypotheses "(A XOR B) OR NOT C" in the original case and "(A XOR B) AND NOT C" in the modified case, and probably something similar in the third case.
How is the NN supposed to know that you didn't want these, but "A XOR B"?
In general training a neural net on such a small input space and with fixed results for each possible input rarely works because there are always multiple possible hypotheses.
