New Nuclear Reactor Design: Desired Features & Goals
  • Thread starter Thread starter edpell
The discussion centers on desired features and goals for new nuclear reactor designs, focusing on safety, efficiency, waste management, and operational costs. Participants explore various reactor types, including liquid metal and molten salt reactors, and their potential advantages and challenges.
  • One participant expresses a desire for reactors to operate at no pressure above 1 atm in the core, citing safety concerns.
  • Another participant argues that achieving less than 1 atm in the core is impractical due to physical principles related to mass and pressure.
  • Several participants emphasize the importance of passive cooling systems for shutdown scenarios to enhance safety.
  • There is a call for reactors that produce less waste, with a specific interest in reducing the lifetime of nuclear waste to under 1000 years.
  • Some participants propose that molten salt reactors could theoretically operate at ambient vapor pressure, potentially improving safety and efficiency.
  • Concerns are raised about the security costs associated with smaller, modular reactors compared to larger plants.
  • Participants discuss the potential for new designs to incorporate advanced safety features that have been developed since older reactors were built.
  • There is a suggestion that future reactor designs should aim for higher energy conversion efficiencies, potentially avoiding the need to boil water.
  • Some participants highlight the different priorities and challenges faced by developed versus developing countries in nuclear reactor construction and deployment.
Participants express a range of views on the feasibility and desirability of various reactor features, with no clear consensus on the best approach or design. Disagreements exist regarding the practicality of operating at low pressures and the implications of different reactor types on waste management and safety.
Participants acknowledge limitations in current reactor designs, including the challenges of waste management and the need for robust safety features. The discussion reflects a variety of assumptions about the capabilities and operational requirements of different reactor technologies.
edpell
What features do you want in a new nuclear reactor design?
I want:
1) no pressure above 1 atm in reactor (OK in secondary heat loop and turbine)
2) passively cooled on shutdown (planned and unplanned)
3) waste lifetime < 1000 years
4) small amount of waste (relative to current day LWR)
5) known reserves of fuel for 200 years of planet at 10 billion people each at 1KW continuous
As far as I can tell LFTR reactors meet all of these. What are you looking for and do you see a reactor design that meets all your goals?
One will not get less than 1 atm of pressure in the core, because all material have mass/density and pressure goes with mgh or ρgh (head) and fuel has to have some volume = lateral area x height. One may ask for vapor pressures less than some value. Even liquid metal reactors operate at up to 5 atm of pressure - but they are liquid metal.
Then there is the secondary/tertiary power loop which might be the Rankine steam cycle, and many steam cycles operate with as high as pressure as possible. PWR secondary side and BWR primary side has high pressure of ~1000 psia.
The waste (fission products) will be there. Given about 200 MeV/fission, there is not a lot of way to reduce the fission products per unit energy. One can use thorium which produces less transuranics, but is does produce some because thorium based systems produce and use U233, which can become U234, U235, U236, . . . , but much less TU than with U238 in the system. And the structural materials become activated.
I want the passive cooling on shutdown. In my mind, the decay heat is the biggest difference between a reactor and any other energy source. The lack of a true 'off switch' is a fundamental property of the nuclear unit. A completely robust passive solution would go a long way to improve safety.
A smallish, turn-key plant with fixed design, cost, and pre-licensed for operation, $500 million for 300 MWe, with passive safety capability. Like a cheaper, miniature ESBWR.
If we're talking future designs, I'd like to see something that doesn't need to boil water. Or at least better than 35 % efficiency.
Given that the reactors in the Japan incident were 40 years old, what do the newer plants already have for additional safety features?
Passive cooling - for using natural convection and condensation to transfer heat in containment.
I expect they also have their emergency diesel generators in a safe place, but ostensibly they don't count on the need for electrical power to cool a reactor.
Excellent.
The existing http://en.wikipedia.org/wiki/Pressurized_water_reactor" for all types of heat cycles, and thus molten salt presents a solution for a high energy-conversion-efficiency reactor.
Yes, that seems to the most promising business model, except for the security aspect. That is, one has to be able to scale down the small fortune spent on security (upfront and recurring) at a 1GW plant down 3X to your 300 MW turn-key, and I don't think the NRC or the industry will allow that to happen, and thus threaten the status quo.
A molten salt reactor could theoretically run at ambient vapor pressure, and it is the vapor pressure that drives the design of the pressure vessel (what, 20cm steel in a 150 atm PWR?).
With molten salt the idea would be to go with http://en.wikipedia.org/wiki/Brayton_cycle" operate(d) at 650C and up.
True, though in a molten salt reactor the fission products merge only as ionic salts (e.g. fluoride salts), not as elements that might readily enter biological pathways if exposed to the environment.
Yes, far less transuranics is a rather large advantage of Thorium as it is the TUs that extend the waste hazard window out to thousands or years versus tens or hundreds for a system with no TU.
Yes, but is that not true for any neutron producing nuclear reaction?
The plants would most likely be built as add-on units to existing sites so I don't think the marginal security cost would not that significant.
Good idea, though it restricts one of the large advantages of small-modular: distribution close to the demand/load, esp. in developing countries where there are no existing big nukes.
Well I am more focused on desired features for America/Europe, where the big problem is the risk involved for private companies building multi-billion dollar reactors that take years to construct. China/India etc have different priorities in that they are more likely to have government financed construction of new large multi-reactor power stations for their growing economies.
I'm not sure can remove developing from developed (nuclear) in this case, as one of the enablers for small-modular is large quantities and thus greater economy of scale which gets one to the cost of $1-2 per Watt you referenced.
Yes, I'm a PWR-physicist myself. Every power plant (fossile or nuclear) boils water. Only difference is how. I was more thinking of something that can convert radiation to electricity directly. Kind of like a solar cell. It's done all the time in neutron detectors but I guess it would be impractical for power generation and probably give less efficiency than boiling water.
If it uses water.
You may be interested in this 2009 thread in this forum, https://www.physicsforums.com/showthread.php?t=307262&highlight=photon", which discusses some of the two step nuclear radiation conversion work (nuclear radiation -> UV fluorescer -> UV photons -> UV photovoltaics) done by George Miley and Prelas in the 1990s, among other related topics.
http://prelas.nuclear.missouri.edu/Publications/PIDEC Fission Conversion.pdf"
The neutrons themselves only account for ~5% of the energy released from fission. A majority of the energy is the kinetic energy of the fission fragments (i.e. heat).
You can turn the heat of fission directly into electricity using a Stirling engine, however it is less efficient then the currently used steam cycles.
There are also materials which can directly turn radiation into electricity called beta voltaics. However the problem is that the radiation tends to quickly degrade the material.
Yes, I forgot this. But agree that much of power generation is done by converting heat to electricity, a technology that is about 150 years old. "There's got to be a better way", David Olive.
The wheel is thousands of years old too, but we still use it. Would you say we haven't had any improvements on the wheel in that whole time?
Steam turbines and other ways to capture heat to produce electricity has improved drastically in 150 years.
Production of electricity using heat engines is also 'drastically' limited by thermodynamics. If I had to guess I'd say heat engines won't see the 22nd century, giving way to some kind of electromagnetic process without those efficiency limitations.
I could see this only if:
A. We find some way to convet heat to something else instead of using it in a turbine or other heat engine.
B. If our primary means of producing power goes to something like aneutronic fusion where the primary source of power is charged particles.
https://www.physicsforums.com/showpost.php?p=3313487&postcount=17
But why is using water as the working fluid intrinsically bad?
Sure, it limits the system temperature a bit, and thus limits thermodynamic efficiency. But it's cheap, abundant, has a high specific heat capacity, and its chemical, thermodynamic, radiochemical and hydraulic characteristics are extremely well characterized.
We can get a bit higher than 35% out of the heat engine, but getting roughly ~50% is about the best you will get in the real world. As a famous nuclear power plant operator once said... In this house, we obey the laws of thermodynamics!
I want:
Either IFR or LFTR both seem to tick all the boxes here.
I want
- dual-loop, passive circulation air cooling (to be used for electricity generation and as process heat),
- 100% fuel burnup
- no leftover daughter nuclides and if that means lower energy efficiency, so be it
- passive safety features that control reactivity with no automation or user interaction required
- total independence from the power grid (to include an ability to store/use power locally instead of scramming when there is low/no demand)
- unattended operation - startup to safe shutdown with no user interaction required, automation designed to cover multiple simultaneous failure modes.
- direct conversion from hard radiation, alphas and betas to electricity
Oh, and a core catcher that works. And zero emissions (yes, Kr and Xe do count).
And a pony?
I want:
Add
(6) not-reactive coolant. (In particular, sodium cooling is bad. Imagine how much worse Fukushima would be if its reactors were leaking not just radioactive water, but radioactive, corrosive, burning SODIUM!)
I also like lead-bismuth fast reactor. It seems to fulfil all of the above, sans "passively cooled on shutdown". But safer post-shudown-cooling is not an insurmountable problem for any reactor - just have a large enough pond nearby, and piping to feed water from it by gravity alone...
I agree on the second point and wonder why IFR research was stopped.
On the first point, water is bad in the primary cooling of the core because it is high temperature, high pressure water if there is a leak it flashes to steam so a large high pressure containment dome is needed and primary cooling is lost. A leak with say liquid salts just means there is a lump of solid salt on the floor and loss can be made up by pumping more liquid salt into the loop. The pumping is easy because it is at room pressure not 400 psi.
Water in the secondary loop is fine. If it fails that just means the turbine stops. It fails safe.
The bad thing about water is actually only high pressure. High temp is intrinsically needed with any coolant, in order to obtain good conversion efficiency. The leak also can cause loss of cooling with any coolant, not limited to high pressure one. However, high pressure coolant, such as water, will boil out and thus escape even through a leak at the top. Molten salt or molten lead wouldn't.
Basically - it is the corrosion metals in water that is the issue, as well as the high pressure, which increases with temperature. Metals prefer to revert to oxides if given the chance.
  • Poll Poll
12K
  • · Replies 16 ·
